HIGH BOOST JDM B16a converted to no-vtec
i have a b16a bottem end and want to convert from a previous vtec motor to a non-vtec motor (head on a friends cr-vtec all motor) ... i plan on running the 1.6 block with an ls crank and head ... also does anyone have any experiance with the rod situation , does it need modded or which rods to use ... planning on a full stock motor with high boost with very good tunning just to see if it works just for the hell of it ... info would help guys if you got it thanks
Re: (nigel)
from what i hear the ls crank with add some displacement or atleast torque to the motor... at least thats what i hear ... im just doing some research before i actually do it
Re: HIGH BOOST JDM B16a converted to no-vtec (b20turboic)
it can be done...but it's a waste of time. why not just get an ls and save yourself the trouble?!? you may experience oil leak problems from the oil ports on the vtec block and you'll have to drill the dowels on the vtec block to accept the pins on the ls head...or vice versa. my .02, just get an ls motor if you want the extra displacement and want to stay non-vtec.
Re: HIGH BOOST JDM B16a converted to no-vtec (shermanyang)
i have a 94 ls i got for 100 bucks perfecto condition but i wanna be different and hit 11's .... my b20b i have in right now at 11.5-12 should be good for an 11.9 or so on slicks so we will see
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">it can be done...but it's a waste of time. why not just get an ls and save yourself the trouble?!? you may experience oil leak problems from the oil ports on the vtec block and you'll have to drill the dowels on the vtec block to accept the pins on the ls head...or vice versa. my .02, just get an ls motor if you want the extra displacement and want to stay non-vtec.</TD></TR></TABLE>
i agree with him just get the ls. no point of a 1.6 ls, 1.8 aint that fast already haha
coquieg6
08-19-2009 08:05 AM
truckhigh
06-13-2005 07:50 AM
