Compression/Timing question...
Old Sep 23, 2003 | 06:10 PM
TurboJesse
Guest
Posts: n/a
Default Compression/Timing question...
did a compression test on my b16 with 3mm headgasket a few days ago and go ~95,95,95,95, this was done on an extremely cold start. anyways looking over my timing today i realized the T-belt was a tooth off, could that effect teh compression that much? i did a test before i installed teh headgasket and got 205,205,205,205 so i know its not internals....
Old Sep 23, 2003 | 06:13 PM
Andrea's Avatar
Default Re: Compression/Timing question... (Mpir3)
Yes, it will effect compression. The valves will open during the compression stroke and bleed out the pressure that is supposed to build up.
Old Sep 23, 2003 | 06:20 PM
TurboJesse
Guest
Posts: n/a
Default Re: Compression/Timing question... (50trim EK)
The timing is fixed now...Gonna do another test tomo
Panoply
14
Jun 5, 2012 07:38 AM
ca-rs
May 9, 2008 12:53 PM
TurboJesse
10
Sep 16, 2003 05:06 PM
