Problem with my nitrous..
Old Sep 23, 2003 | 05:29 PM
tgreaves's Avatar
Default Problem with my nitrous..
I have a 89' crx dx with the dpfi injection on it.. I installed a zex dry kit with a 55 jet in it.. My problem is this, When I spray in 1st gear the car hauls *** like it should.. Any other gear it goes up to about 4k and studders kinda like its hitting a rev limiter.. This happens only when im spraying but runs perfect when im not spraying.. Any help here...
Old Sep 23, 2003 | 06:44 PM
bottlefedb18c1's Avatar
check your plugs they can be burnt up and you might be detonating and that is the miss
but put some new colder plugs in and try it from there
Old Sep 23, 2003 | 06:48 PM
Jared's Avatar
Default Re: Problem with my nitrous.. (tgreaves)
wow, you're brave. two fuel injector spray and pray + a dry kit.
Old Sep 24, 2003 | 04:42 AM
tgreaves's Avatar
Default Re: Problem with my nitrous.. (Jared)
Very brave.. I have 2 more engines to blow up so it doesnt matter..
The plugs that are in there are ngk v-core plugs that are 2 heat ranges colder than stock and the are brand new..
Old Sep 24, 2003 | 06:11 AM
xci_ed6's Avatar
check the gap. With the nitrous you will be running much higher cylinder pressures, and may be drowning out the spark. On the DPFI I would recomend a direct port wet system (I think I may have a mani laying around that is already tapped). The weakness of the DPFI system is the 1.25" TB, and much better results can be had if you spray on the other side of the resriction.
-Dustin
Old Sep 24, 2003 | 06:26 AM
tgreaves's Avatar
Default Re: Problem with my nitrous.. (krustindumm)
Should the gap be bigger or smaller than stock.. Also how far from stock should I gap the plug
Old Sep 24, 2003 | 07:56 AM
xci_ed6's Avatar
stock or slightly smaller should work. Just make sure they aren't way to big.
Another thing to check is your fuel system. Since the problem is at high revs with nitrous (need more gas for both), it could be a fuel system problem. Put a new fuel filter (regular maintenence anyway) in and if that doesn't solve it put a guage on to watch fuel pressure during a run.
-Dustin
Old Sep 24, 2003 | 09:42 AM
laughinxxx's Avatar
New User
sounds like you are misfiring. I'd check plugs or wires first.
Old Sep 24, 2003 | 09:46 AM
tgreaves's Avatar
Default Re: Problem with my nitrous.. (laughinxxx)
I has a brand new fuel filter on it.. Ill try the gauge thing and let you know.. It actually does sound like a misfire.. Im gonna check the plugs tonight and regap them a little smaller..
Old Sep 24, 2003 | 10:10 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Should the gap be bigger or smaller than stock.. Also how far from stock should I gap the plug</TD></TR></TABLE>
.032 gap. Your detnationg. not enough fuel
Old Sep 24, 2003 | 10:18 AM
gitwidit's Avatar
Default Re: Problem with my nitrous.. (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
.032 gap. Your detnationg. not enough fuel</TD></TR></TABLE>
werd, either timing or fuel.
Old Sep 24, 2003 | 10:40 AM
tgreaves's Avatar
Default Re: Problem with my nitrous.. (GITWIDIT)
WOW.. That far of a gap differance.. Right now I have the plugs gapped at .044
Old Sep 24, 2003 | 01:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I belive it's .032 check to make sure. I haven't dealt with nitrous in a while but that's what my plugs are for turbo. May not be ther ame. I can
t seem to remember.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">WOW.. That far of a gap differance.. Right now I have the plugs gapped at .044</TD></TR></TABLE>
Old Sep 24, 2003 | 03:51 PM
i went with a .032 gap and never had problems other then the plugs burn up faster with the spray
Old Sep 24, 2003 | 05:03 PM
-Trinitron-'s Avatar
drop your timing back like 2 degrees and adjust the gap. You "should" be good to go.
Old Sep 24, 2003 | 05:31 PM
Default Re: (-TRINiTRON-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">drop your timing back like 2 degrees and adjust the gap. You "should" be good to go.</TD></TR></TABLE>
yes and if you still have that problem check your fuel pressure
Old Sep 25, 2003 | 05:50 AM
tgreaves's Avatar
Default Re: (bottlefedb18c1)
I still have a problem.. I adjusted the gap from .44 to .38 and then down to .32 and same results.. I adjusted the timing from stock to full retard and same problem.. Im guessing its either my ignition system isnt hot enought to fire the plugs when spraying or its a fuel pressure problem.. Funny thing is I check the plugs for signs of running lean or detonation and their fine.. Ill put a pressure gauge on it and see what the results are.. If that doesnt fix it im going to just put my other motor (93 civic dx) in there since it is newer and has the mpfi injection on it..
Old Sep 25, 2003 | 07:54 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (tgreaves)
I think the multipoint would be a good idea. Are you using a stockf-regulator?
Old Sep 25, 2003 | 09:37 AM
xci_ed6's Avatar
Default Re: (HybridcivicLS-T)
for the fuel pressure, make it so you can watch it while driving, the pressure should jump when you hit the button, then stay somewhat constant to redline. My guess is that it starts dropping when your car starts hesitating.
To read the plugs you need to shut off the ignition WHILE the car is hesitating, immediatly afterwards is not soon enough.
-Dustin
Old Sep 25, 2003 | 10:25 AM
tgreaves's Avatar
Default Re: (krustindumm)
Right now I am using the stock fpr.. My friend is bringing his fuel pressure gauge over tonight so ill check and see if its a fuel problem or a ignition problem.. Is it also possible that the dpfi injection cant keep up since it only have 2 injectors in it..
Old Sep 25, 2003 | 02:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I still have a problem.. I adjusted the gap from .44 to .38 and then down to .32 and same results.. I adjusted the timing from stock to full retard and same problem.. Im guessing its either my ignition system isn't hot enought to fire the plugs when spraying or its a fuel pressure problem.. Funny thing is I check the plugs for signs of running lean or detonation and their fine.. Ill put a pressure gauge on it and see what the results are.. If that doesnt fix it im going to just put my other motor (93 civic dx) in there since it is newer and has the mpfi injection on it.. </TD></TR></TABLE>
dumb question but did you ever check to see if both noids are working? and you have the right jets in?
Old Sep 26, 2003 | 06:03 AM
tgreaves's Avatar
Hmmm.. Ill check to make sure the correct jets are in there but im sure they are.. Also I know the nitrous noid is working fine but how do I tell if the fuel part of it is working ok..
Old Sep 26, 2003 | 06:12 AM
tegasaurus's Avatar
[QUOTE=tgreaves]Problem with my nitrous..[QUOTE]
wait wait wait... back up here.... you're having problems with your nitrous? that's hard to believe Just busting ur ***** man
Like everyone else is saying, its definatly something with the spark system. First is the check or replace the plus (possibly go colder) - Check the wires (when were they last replaced?) - Then try to replace the distributor, also what octane gas was in the tank at the time (had it been sitting a long time?).
-ryan
Old Sep 26, 2003 | 07:14 AM
tgreaves's Avatar
Default Re: Problem with my nitrous.. (tegasaurus)
Plugs are brand new and are 2 heat ranges colder.. Wires are brand new.. I have fresh 93 octane gas in the car.. Im going to put my new motor in and ill see if it still does it then.. Its either a fuel problem or a spark problem..
Old Sep 27, 2003 | 05:41 PM
it might a week coil i have seen that in the past myself
but go though everything and see how it all looks
you can disconect one noid at a time with the car off and check each noid if they are opening or at least clicing
becouse it is hard to hear both opening at the same time
it is just a though
