How to create 0 boost?
Old Oct 3, 2003 | 07:47 AM
intekragsr's Avatar
Default How to create 0 boost?
If I dont want to create boost (breaking in motor), can I just completly remove the Tial WG spring? It makes sense to me, but maybe I am missing a factor in the equation?
Old Oct 3, 2003 | 07:50 AM
boosted hybrid's Avatar
Default Re: How to create 0 boost? (intekragsr)
Just take the spring out. You wont have enough exhaust energy to get the turbine/compressor shaft into the rpm range to generate boost pressure. I have done the spring trick for many cars, and no boost is generated if the placement of the wastegate is efficient.
Old Oct 3, 2003 | 07:51 AM
bryan305's Avatar
how bout you put the filter on the charge pipe, and just leave the turbo disconnected from the intake?
Old Oct 3, 2003 | 08:00 AM
shermanyang's Avatar
Default Re: How to create 0 boost? (bryan305)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">how bout you put the filter on the charge pipe, and just leave the turbo disconnected from the intake?</TD></TR></TABLE>
i've heard that you could destroy your turbo by doing this. the reason was because you need some resistance on the compressor side...etc, etc....i forgot.
Old Oct 3, 2003 | 08:01 AM
PM-Performance's Avatar
yea me and jeff did the wg spring trick when doing my partial throttle tuning before, works great. its not hard not to boost though when breakign the motor in , i just didnt get on it, and eased the rpms up to seat the rings. just takes will power not to boost
Old Oct 3, 2003 | 08:11 AM
intekragsr's Avatar
Default Re: How to create 0 boost? (itr206)
Well being that I havent driven my car in 6 months, I dont see how its possible for me to resist boosting
Thanks for the quick replies. I will take the spring out. This will obviously make my car sound like a donkey correct?
Old Oct 3, 2003 | 08:19 AM
it will sound nasty if you try to create boost and the spring is out , correct.
Old Oct 3, 2003 | 08:35 AM
R6Elmo's Avatar
This is a really bad idea. You'd basically be leaving no resistance to the turbo. It would therefore spin 'infinetely".
Old Oct 3, 2003 | 08:45 AM
intekragsr's Avatar
Default Re: How to create 0 boost? (R6Elmo)
Yea, when my intercooler piping popped off in the middle of nowhere, I had to drive miles before I could fix it. I think thats why my turbo makes funny noises now when I sping the wheel Rebuild is coming up after my motor is broken in.
Old Oct 3, 2003 | 10:27 AM
inspyral's Avatar
You could also just leave the w/g off completely. Yes, that does sound like ***
Old Oct 4, 2003 | 05:41 PM
intekragsr's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You could also just leave the w/g off completely. Yes, that does sound like *** </TD></TR></TABLE>
Haha if I just leave it off the manifold, wont that nuke my engine bay?
Old Oct 4, 2003 | 05:50 PM
Happyman's Avatar
Default Re: (intekragsr)
They make wastegate flange blockers. Just a peice of metal covering it.
Old Oct 4, 2003 | 06:41 PM
Alstare's Avatar
Default Re: (eh6turbo)
If you block your wastegate and go WOT your not gonna be too happy with the results
What company sells these "wastegate flange blockers"???
Old Oct 4, 2003 | 06:51 PM
Raunch's Avatar
Default Re: (Alstare)
Look what happened to me and all I was missing was the dump tube Now imagine what would happen if you dont have the wastegate at all
Old Oct 4, 2003 | 07:06 PM
Johnyquest's Avatar
Default Re: (Raunch)
I say find that website that teaches you how to break in a motor BY beating on it... then just go out and let 'er rip
Supposedly works better than normal breakins, and is hell-of-alot more fun!
I found the website for everybody... it's rather interesting!
http://www.mototuneusa.com/break_in_secrets.htm
Old Oct 4, 2003 | 07:17 PM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">
True. You'll over spin the turbo.
Old Oct 4, 2003 | 07:19 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">Yea, when my intercooler piping popped off in the middle of nowhere, I had to drive miles before I could fix it. I think thats why my turbo makes funny noises now when I sping the wheel Rebuild is coming up after my motor is broken in. </TD></TR></TABLE>
damn.. that sucks.. same thing happend to me.. and i drove several miles too.. did you turbo start to maka that noise right-a-way? how long did it take for that noise to happen?
Old Oct 4, 2003 | 07:24 PM
intekragsr's Avatar
Default Re: (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">I say find that website that teaches you how to break in a motor BY beating on it... then just go out and let 'er rip
http://www.mototuneusa.com/break_in_secrets.htm </TD></TR></TABLE>
Yea I read that site, but it says nothing about beating on it hard WITH BOOST. I wanna beat on it NA.
Old Oct 4, 2003 | 07:25 PM
intekragsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6turbo &raquo;</TD></TR><TR><TD CLASS="quote">They make wastegate flange blockers. Just a peice of metal covering it.</TD></TR></TABLE>
That will make my spool infinite psi, right?
intekragsr's Avatar
Default Re: How to create 0 boost? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
damn.. that sucks.. same thing happend to me.. and i drove several miles too.. did you turbo start to maka that noise right-a-way? how long did it take for that noise to happen?</TD></TR></TABLE>
It happened to me 2 times. And then I noticed the strange noise. It sounds like metal rubbing metal. When it happened the first time, I didnt think it was bad, so I decided to have fun flooring it to bring back the memories of all motor weakness. It also made a cool hairdryer sound with no piping. But then I realized it was bad...
Old Oct 4, 2003 | 10:03 PM
Alstare's Avatar
That will make my spool infinite psi, right?</TD></TR></TABLE>
Yes you will spool untill something pops... I'd say within about 3 seconds of spool up you'll hear some bad noises followed by alot of smoke and shrapnell
Old Oct 4, 2003 | 10:08 PM
Happyman's Avatar
Oh guess I should have mentioned people use them with manifolds when they go internal wastegate
Old Oct 4, 2003 | 10:55 PM
mskibbz-T's Avatar
It happened to me 2 times. And then I noticed the strange noise. It sounds like metal rubbing metal. When it happened the first time, I didnt think it was bad, so I decided to have fun flooring it to bring back the memories of all motor weakness. It also made a cool hairdryer sound with no piping. But then I realized it was bad...</TD></TR></TABLE>
My turbo sounds like that My spool sounds like a garbage disposal... I've blown off my IC piping a couple times, but nothing too bad. I haven't thought much of it until I read this thread... what kind of bad things does that noise suggest?? Is it in need of an immediate rebuild?
Old Oct 4, 2003 | 11:57 PM
intekragsr's Avatar
Default Re: How to create 0 boost? (mskibbz-T)
I dont know what the noise actually means. Maybe some shaft thingy-ma-bobb inside the turbo got bent? Haha im clueless. Even though it makes the sound, the car still pulled hard. Im definatly going to do a rebuild though.
andrew1320
Feb 23, 2012 07:13 AM
h22civicek
Apr 6, 2009 07:42 PM
turbo95eg6
Jun 12, 2005 07:46 PM
mildly.interesting
Jan 1, 2005 05:36 PM
5l-eater
Oct 20, 2004 03:26 PM
