detnating in boost...help
Old Oct 2, 2003 | 06:57 PM
chinners10's Avatar
Default detnating in boost...help
does anyone have any ideas to prevent some detnating????
Old Oct 2, 2003 | 07:04 PM
InTeGrA B18b1's Avatar
Default Re: detnating in boost...help (cxhatch02)
colder plugs, retard your distributor, run higher octane, turn boost down
Old Oct 2, 2003 | 07:07 PM
racinskittle's Avatar
Default Re: detnating in boost...help (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">colder plugs, retard your distributor, run higher octane, turn boost down</TD></TR></TABLE>
Well after doing all that i hope he wouldn't have to turn the boost down
Old Oct 2, 2003 | 07:16 PM
chinners10's Avatar
Default Re: detnating in boost...help (racinskittle)
what kind of plugs??? and i did retard my distributor, and im running 92 octane... so what kind of plugs should i get??? thanks for the info
Old Oct 2, 2003 | 07:20 PM
intekragsr's Avatar
NGK BKR7E, part number 6097
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxhatch02 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of plugs??? </TD></TR></TABLE>
Old Oct 2, 2003 | 07:25 PM
chinners10's Avatar
Default Re: detnating in boost...help (intekragsr)
sweet... thanks
how about higher octane??? should i put some octane booster in or is that stuff crap??
Old Oct 2, 2003 | 07:27 PM
intekragsr's Avatar
dont waste your money on octance boosters. All you need is good tuning. The end
Old Oct 2, 2003 | 07:42 PM
Agtronic's Avatar
How much boost are you running?
Octane booster would work, but do you really want to have to put in extra stuff in the fuel every time you fill-up?
Old Oct 2, 2003 | 07:44 PM
chinners10's Avatar
Default Re: detnating in boost...help (Agtronic)
4-5 psi...
Old Oct 2, 2003 | 09:14 PM
Del_Slowest's Avatar
how come nobody has said MORE FUEL? all the other opinions are nice and very well educated, but what about the best instant fix....fuel...
Old Oct 2, 2003 | 09:40 PM
Hoosier Daddy's Avatar
Default Re: detnating in boost...help (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest &raquo;</TD></TR><TR><TD CLASS="quote">how come nobody has said MORE FUEL? all the other opinions are nice and very well educated, but what about the best instant fix....fuel... </TD></TR></TABLE>
I was thinking the same thing. What kind of fuel mods/management do you have?
Old Oct 3, 2003 | 07:37 AM
intekragsr's Avatar
Default Re: detnating in boost...help (Boost Creep)
I said "Tuning"
Thats all you need.
Old Oct 3, 2003 | 08:10 AM
PrecisionH23a's Avatar
At 4-5psi you should not need a higher octane fuel.
If I were you I would get over to a dyno asap for some fine tuning. I recommend the NGK BCPR7ES, part number 3330, gapped to around .030
Old Oct 4, 2003 | 01:06 PM
Agtronic's Avatar
Default Re: detnating in boost...help (GudeH23a)
Yeah, at 4-5 psi you really shouldn't be detonating. Get a wideband on that thing!
Old Oct 4, 2003 | 01:39 PM
Killer_B's Avatar
get a wideband? does money grow on trees?
at 4-5psi you should not be detonating. double check everything, there is no reason why you should be detonating. i was checking your Sig and i don't see info on tuning or at least an FMU.
it's easy to say "tune you car" but noone wants to spend money on Dyno sessions when their not done with the final project. just check everything and make sure it's 100% until you're ready to tune it properly.
Old Oct 4, 2003 | 09:59 PM
Agtronic's Avatar
Default Re: (Killer_B)
No, money does not grow on trees, and that's exactly the reason you should rent a wideband. It's alot more expensive to replace a blown block than it is to spend the $100 on dyno time, or wideband rental.
You don't get this far and say "it's too expensive to tune it". That's part of the price.
If you're cheap (as am I), build a DIY-WB. Mine cost a total of $200 US and it works like a charm. I've tested it against a Motec unit and it was dead on. I think $200 is reasonable considering this is a TURBO project.
How are you adding fuel? Do you have an FMU in the "stuff I can't remember" department?
Old Oct 4, 2003 | 11:37 PM
sharkcohen's Avatar
Default Re: (Agtronic)
This isn't an inexpensive hobby, and improper tuning can end up costing you a hell of a lot more than the cost of proper tuning. Either foot the bill for some tuning or for a wideband and tune it yourself.
Old Oct 6, 2003 | 07:56 PM
chinners10's Avatar
i have a Vortech FMU.....
Old Oct 6, 2003 | 08:10 PM
ion_four's Avatar
Default Re: (cxhatch02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxhatch02 &raquo;</TD></TR><TR><TD CLASS="quote">i have a Vortech FMU.....</TD></TR></TABLE>
That's the problem, you're only tuning option is changing discs, or upping baseline pressure. These do not offer much to work with. Since you've obviously dropped alot of money on all the other quality parts, atleast get an AFC, or reprogrammed ECU.
Old Oct 8, 2003 | 04:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">
i was just giving examples of what to do. i'd turn the boost up after that
Old Oct 8, 2003 | 05:23 PM
Sohc Driver's Avatar
are you detonating right now..or are you just asking what to do to prevent detonation?
Khoi
Old Oct 8, 2003 | 06:44 PM
chinners10's Avatar
Default Re: detnating in boost...help (Sohc Driver)
im detnating now when i get up to about 4,500 to 5,000 rpms...
Old Oct 8, 2003 | 07:57 PM
are you sure you detonating? could be rocks in your cat or something haha
Old Oct 8, 2003 | 08:57 PM
could it be possible you have your hoses connected to your FMU incorrectly?
Khoi
Old Oct 9, 2003 | 01:22 AM
Agtronic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxhatch02 &raquo;</TD></TR><TR><TD CLASS="quote">im detnating now when i get up to about 4,500 to 5,000 rpms...</TD></TR></TABLE>
Are you sure you have 8.8:1 pistons? Did you install them yourself? This recently happened to a guy on the vortex and he just couldn't figure it out. The shop that build the block had ordered 8.5:1 pistons for a VR6 and they received 11:1 units by mistake. They didn't notice and installed them.
VR6 engine mangement users
Compression test results ( 1 2 )
