what should timming be set at w/ turbo?
sup i have a 94 teg. I was wondering when boosting... do u retard the timing? or leave it stock? thanks a lot fo your help guys
Re: what should timming be set at w/ turbo? (ha illuminato un)
im running on a basic t25 setup with about 5lbs boost right now... would that help?
Re: what should timming be set at w/ turbo? (bumsta217)
Try using the search function. Be more specific than just "basic t25 setup with about 5lbs boost". Fuel? Engine management? Intercooled? I know your sig says 94 LS but who knows if the motors the same or stock. You need to help yourself before we can help you. I personally think on a B18b you can leave it at stock timing if your only running 5 psi on a t25 no matter what the fuel setup (assuming you have a boost referenced fuel supply).
Re: what should timming be set at w/ turbo? (highmilehatch)
what would you recommed timing for a stock bottom end jdm b16 inline pro manifold sc50 running 9psi it is intercooled, walbro 255lph intank, rc 440's and smc to control fuel? thanks
