jrsc/vafc help
Old Oct 3, 2003 | 06:19 PM
94jaxgsr's Avatar
Default jrsc/vafc help
I just had a VAFC installed on to my GSR i am running a 8lb pulley but for some reason yesterday when we were trying to tune the fuel i was hitting 13lbs on the boost guage. not sure that was right because when i got near my house when i was messing with the fuel i got on it the boost faded and bam my belt exploded ( the one going from the supercharge to the altenator) so now i need a new belt. but was wondering if any one has any sugestions as far as tuning the fuel on the VAFC. i am running 440cc imjectors so i dont know where to set the % at so i wont have to run a FMU. Or should i run one to be safe? and what are the thoughts on the 13lbs i was hitting? was it because of to much fuel? thanks
Old Oct 3, 2003 | 06:32 PM
greekspeed's Avatar
Default Re: jrsc/vafc help (94jaxgsr)
how much boost u make with the jrsc has absolutly nothing to do with how much fuel u have... its all about the the pulleys and belts, and size of the blower....... my guess is either ur gauge is messed up..... or u tightend the **** out of ur belt so that there was little or no belt slip and caused u to gain a little more boost and at the same time blew the belt because it was over tightened so much..
but even if it wasnt over tightened belts go bad... its a common thing with roots type blowers.
Old Oct 3, 2003 | 06:39 PM
94jaxgsr's Avatar
Default Re: jrsc/vafc help (greekspeed)
so what would you recomend about the fuel on the VAFC?
Old Oct 3, 2003 | 06:51 PM
B94Cast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94jaxgsr &raquo;</TD></TR><TR><TD CLASS="quote">so what would you recomend about the fuel on the VAFC?</TD></TR></TABLE>
If you are referring to what base map to start out with, start at -40% and watch your A/F gauge ... tune from there.
HYREV2NR
Sep 10, 2004 05:55 PM
Westsideboy
Apr 22, 2004 08:21 PM
01SH
Jan 16, 2003 08:27 PM
fastfour
Jul 6, 2001 11:18 PM
