Help tuning Uberdata!
Old Oct 1, 2003 | 06:12 PM
red_sir's Avatar
Default Help tuning Uberdata!
Setup is:
-2000 SiR
-converted to OBD1 with P28 and Uberdata
-DSM 450's
My problem is I'm having a really high and rich idle. It idles at 950rpms and the A:F reads 10.6. I've leaned it out A LOT and it's still like that. I've also set the IACV tab all the way to the right but no luck in bringing the idle down. Any ideas/tips? Thanks.
Old Oct 1, 2003 | 07:12 PM
Mr. Softee's Avatar
Default Re: Help tuning Uberdata! (red_sir)
its probably from the injectors, not uberdata. mine did the same thing sometimes w/ dsms
sam
also make sure you have no vaccum leaks
Old Oct 1, 2003 | 08:01 PM
red_sir's Avatar
Default Re: Help tuning Uberdata! (94goldjungsr)
I don't think it's the injectors because I didn't have this problem when I was running the hack.
Old Oct 1, 2003 | 08:17 PM
Mr. Softee's Avatar
are you throwing any CELs
Old Oct 1, 2003 | 08:22 PM
red_sir's Avatar
No, just a stinking rich idle. =/
civperc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">its probably from the injectors, not uberdata. mine did the same thing sometimes w/ dsms</TD></TR></TABLE>
sam, what did you do to correct that?
Old Oct 1, 2003 | 08:24 PM
Mr. Softee's Avatar
Default Re: Help tuning Uberdata! (untensadude)
didnt do anything. mine idled at like 2 grand for about 30 seconds when cold. dont know why. couldnt fix it.
as for your uberdata problem send me your map and il look at it. if its for an LS i will send you my map and you can try it, it idled dsm 450s like stock once warm
sam
Old Oct 1, 2003 | 08:30 PM
red_sir's Avatar
You got mail.
Old Oct 1, 2003 | 08:36 PM
Mr. Softee's Avatar
i checked it out. theres no reason for you to be running rich. lean out the 20 and 17 columsn and se eif that helps. you should be able to idle 370-720 injectors with those fuel values. its pretty easy to idle injectors... i once put in a 240cc map for myf riends 550cc car and it idled em
sam
Old Oct 1, 2003 | 09:22 PM
red_sir's Avatar
Sam you genius! I leaned out column 20 and 17 and that did it!
Thanks!
Old Oct 1, 2003 | 10:05 PM
Mr. Softee's Avatar
np
sam
s032105k
Engine Management and Tuning
Apr 12, 2011 10:14 AM
civickiller
May 12, 2010 02:10 PM
jaxx4k
Sep 2, 2005 07:30 PM
lswithvtec
Jun 7, 2004 11:38 AM
0 0 0
Jan 24, 2004 05:15 PM
