how does a bov help
Old Oct 2, 2003 | 03:00 PM
iluvdrt's Avatar
Default how does a bov help
i was just wandering how a bov helps your car, and if you really need one. i am planning to install a tmic and figured i would throw a bov in there to make the sound, but does it really help performance or anything. keep in mind i will be running about 10 psi. my engine is a ea82t subaru engine if it helps. thanks.
Old Oct 2, 2003 | 03:46 PM
MachAF's Avatar
Default Re: how does a bov help (iluvdrt)
A BOV prevents compressor surge.
When your boosting 12 psi and let off the gas to shift the throttle plate closes, where is all the boost going to go?? Very bad for the turbo to surge.
Get a BOV!
Old Oct 2, 2003 | 04:06 PM
iluvdrt's Avatar
so basically its just insurance for the turbo. so why dont all cars come with one?
Old Oct 2, 2003 | 04:10 PM
Ricey McRicerton's Avatar
Default Re: (iluvdrt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvdrt &raquo;</TD></TR><TR><TD CLASS="quote">so basically its just insurance for the turbo. so why dont all cars come with one?</TD></TR></TABLE>
Because all car's aernt turboed!! Also, most stock cars just use the wastegate because they dont usually run high boost!
Old Oct 2, 2003 | 06:41 PM
iluvdrt's Avatar
my bust i didnt mean all cars i meant all turbo cars. anyway so if the boost is low then you dont need one? ill be running 10 psi, would it benifit me?
Old Oct 2, 2003 | 06:57 PM
bigwig's Avatar
10 psi...BOV is a must...unless you like blowing up engines. low boost=5psi...
Old Oct 2, 2003 | 07:05 PM
iluvdrt's Avatar
ok thanks. i was probably going to put one on there anyway because i like the sound. plus it sure would turn a lot of heads in my car.
Old Oct 2, 2003 | 07:15 PM
Dinuguan's Avatar
Well consider this. The Greddy 18G kit for Integras DOES NOT inlcude a bov. Stock spring I think is set to 8lbs. In fact, they don't sell BOVs with either of their Honda kits. So if Greddy can sell it without at bov, you should be fine.
also check out this link:
https://honda-tech.com/zerothread?id=609191
Old Oct 2, 2003 | 07:40 PM
iluvdrt's Avatar
oh i dont own a honda. i have a subaru.check my sig. thanks for all the help.
Old Oct 2, 2003 | 07:54 PM
bigwig's Avatar
greddy kit is set at 7 psi...second of all...the greddy kit also doesnt come w/ an FMIC...7psi and 10psi is 40whp difference.....and it says on the honda-tech site that 10+=BOV...which is exactly what is posted by myself. get a BOV..its only $200 and it will be good as long as you turbo.
Old Oct 2, 2003 | 08:17 PM
twkdCD595's Avatar
Default Re: (bigwig)
at a very low psi I do not think it is detrimental to the life of the turbo to make sure and have a blow off... however on higher boost applications this pressurized force is much greater and turbo spinning that much faster (which takes longer to slow down once you lift (more so with the bigger and ball bearing units).
some cars come factory with a bypass/ blowoff... but not every turbocharged car employs them.
it is a very easily debated topic, much like the turbo timers and water cooling.
Old Oct 2, 2003 | 08:18 PM
90civichbsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvdrt &raquo;</TD></TR><TR><TD CLASS="quote">my bust i didnt mean all cars i meant all turbo cars. anyway so if the boost is low then you dont need one? ill be running 10 psi, would it benifit me?</TD></TR></TABLE>
i havent seen a stock turbo car that doesnt have a bov. rx7s, eclipses, mr2s, supras all come w/ stock blowoff valves, most of the time they are just rerouted back into the intake stream so you dont hear them.
Old Oct 2, 2003 | 08:31 PM
iluvdrt's Avatar
mine doesn't have one, and the factory setting is 8 psi. wierd. but then again i dont think my car was really designed for performance.
Old Oct 2, 2003 | 08:35 PM
twkdCD595's Avatar
Default Re: (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">
i havent seen a stock turbo car that doesnt have a bov. rx7s, eclipses, mr2s, supras all come w/ stock blowoff valves, most of the time they are just rerouted back into the intake stream so you dont hear them.</TD></TR></TABLE>
some turbo volvo's and audi's did not have them until the more recent models.
a bypass valve is what they call them instead when they are just the cheapy recirculating valves.
Old Oct 2, 2003 | 10:39 PM
turbohappy's Avatar
Default Re:
BOV is good. Otherwise you'll spin the turbine backwards (or at least slow it down a lot), which will make it take forever to spool up the next gear and put lots of force on the internals of the turbo. You'll be fine temporarily, but you'll want to get a BOV ASAP.
Old Oct 2, 2003 | 10:52 PM
ConeS's Avatar
Default Re: Re: (turbohappy)
Great info.
Old Oct 2, 2003 | 10:58 PM
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">10 psi...BOV is a must...unless you like blowing up engines. low boost=5psi...</TD></TR></TABLE>
Old Oct 2, 2003 | 11:01 PM
twkdCD595's Avatar
Default Re: Re: (ConeS)
actually the back pressure can eventually blow the seals and pressurize the wrong sections of your turbo which contain lubricant (oil)... thus blowing massive amounts of oil that should be recirculated through your turbo and oil system, into your charge piping and intake. thus you smoke like hell and have to rebuild the turbo eventually or replace it.
edit: my grammar and what not is horrible... it late you get the idea.
97dc2
Jun 9, 2005 08:44 PM
See Are X
Apr 1, 2005 10:12 AM
sLoWrAcEr
Mar 17, 2005 05:48 AM
dunkd
Apr 25, 2004 02:35 PM
Hella Flush Kevin
Mar 15, 2004 03:58 PM
