What Apex'i needs to do to assist with hack.
Old Oct 2, 2003 | 08:57 AM
Quade's Avatar
Default What Apex'i needs to do to assist with hack.
Adjust fuelling from the output side of the ecu. This device will be able to cut injector duty cycle in half to run twice the size of your standard injectors. It will connect between the ecu and injectors. Limit map voltage to the ecu to 3Volts (0psi) and increase fuelling (tunable) upon detecting boost. Therefore it will have it's own map sensor. What they can also include in this device is a tunable boost retard funtion. These would sell like no other electronic device.
let me know what you guys think.
Old Oct 2, 2003 | 09:00 AM
jazz215's Avatar
i like the sound of the boost retard function.. but how much extra would they charge for it? lol like 900 the msrp on the afc is like 495 or something
Old Oct 2, 2003 | 09:48 AM
rioninja's Avatar
Default Re: What Apex'i needs to do to assist with hack. (Quade)
sounds like an emanage.
Old Oct 2, 2003 | 09:57 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">Adjust fuelling from the output side of the ecu. This device will be able to cut injector duty cycle in half to run twice the size of your standard injectors. It will connect between the ecu and injectors. Limit map voltage to the ecu to 3Volts (0psi) and increase fuelling (tunable) upon detecting boost. Therefore it will have it's own map sensor. What they can also include in this device is a tunable boost retard funtion. These would sell like no other electronic device.
let me know what you guys think.</TD></TR></TABLE>
http://www.efisystems.com/pms.html
Fnix
May 17, 2012 03:04 PM
crxsteve
Jan 12, 2007 02:53 PM
jetpilot
Jul 30, 2004 08:52 AM
platinum00
Jun 9, 2003 05:18 PM
