Question regarding internal wastegates.
Old Oct 3, 2003 | 09:12 AM
yellow blur's Avatar
Default Question regarding internal wastegates.
I was just wondering, if someone were to piece together a junkyard kit or their own turbo kit together and they picked up a turbo with internal wastegates how would they adjust boost, by the actuator arm?
For example a wrx turbo is set at around 14psi but for a honda application how would you adjust that down to say 6, 8, or even 10 lbs? Would you just have to bend the actuator arm or what's involved with that. Thanks.
Ed
Old Oct 3, 2003 | 09:36 AM
beefpigs's Avatar
Default Re: Question regarding internal wastegates. (yellow blur)
I'd like to know too.
Old Oct 3, 2003 | 12:34 PM
Default Re: Question regarding internal wastegates. (beefpigs)
Any feedback?
Old Oct 3, 2003 | 12:44 PM
GLHS895's Avatar
i think an MBC would work fine. don't bend the arm, then it'll be hard to put it back the way it was if you ever need to. what some turbo dodge guys do is cut the arm in half, thread both ends and get one of those little connector nuts and that way you can adjust the length pretty easily.
edit:
found a pic:
Old Oct 3, 2003 | 12:48 PM
The Destroyer's Avatar
Default Re: Question regarding internal wastegates. (GLHS895)
I think eh was talking about how to set it, like how if it were a external he would set the spring. Not how to control how much boost.
Old Oct 3, 2003 | 12:53 PM
GLHS895's Avatar
Default Re: Question regarding internal wastegates. (I Need Money.)
whoops. well in that case you can go to the yard and try to find a wastegate that's set for that level of boost and try to rig it up. i don't think you can open up a wastegate and change springs/diaphrams, can you?
Old Oct 3, 2003 | 12:54 PM
stierhund's Avatar
you would have to buy a new vacuum assembly... may be possible to find one with an adjustable actuator, but the best thing to do would be find one w/a really low pressure setting and then use another controller to let pressure through
Old Oct 3, 2003 | 02:40 PM
quis23's Avatar
Default Re: Question regarding internal wastegates. (stierhund)
http://www.gamesbbs.com/~dmoore/turbo-tuning.htm
Old Oct 3, 2003 | 03:03 PM
Eyetattoo's Avatar
Could you just remove the internal wastegate and use a external wastegate? Seems like it would be easier to do that (unless it is hard to convert).
Old Oct 3, 2003 | 03:13 PM
quis23's Avatar
Default Re: (Eyetattoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyetattoo &raquo;</TD></TR><TR><TD CLASS="quote">Could you just remove the internal wastegate and use a external wastegate? Seems like it would be easier to do that (unless it is hard to convert).</TD></TR></TABLE>
what could be easier than adjusting a screw?
yes i can be converted,but i would just rather buy a external.
Old Oct 3, 2003 | 03:25 PM
sporkcrx's Avatar
Default Re: (quis23)
Just hack it in half and thread it. Simple. I did it on my last set up:
Old Oct 3, 2003 | 03:34 PM
Eyetattoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quis23 &raquo;</TD></TR><TR><TD CLASS="quote">
yes i can be converted,but i would just rather buy a external.</TD></TR></TABLE>I was suggesting that if you already had the turbo.
Old Oct 3, 2003 | 04:33 PM
mattb16a1civic's Avatar
could you use an external boost controller say an xs or a homemade or even an electronic one?????? someone fill me in id like ot know for sure wether or not.
Old Oct 3, 2003 | 06:34 PM
sporkcrx's Avatar
Default Re: (mattb16a1civic)
You mean on an internal wg set up? If you mean that, then yes, you can.
Old Oct 9, 2003 | 03:47 PM
Eyetattoo's Avatar
Do you know what the TD05 18G wastegate is set at?
Old Oct 9, 2003 | 04:03 PM
boosted_dc2's Avatar
just weld the flap shut and get an external gate, internal gates suck
abnaasefmb
Jul 28, 2005 10:52 PM
warchild69
Jun 15, 2004 03:53 PM
JonGP4
Dec 19, 2003 08:22 PM
onePOINTsix
Aug 19, 2003 10:59 AM
Mr. Softee
Jul 10, 2002 11:28 AM
