HELP- ? about cel and 02 sensor
Old Oct 2, 2003 | 12:14 PM
98teg's Avatar
Default HELP- ? about cel and 02 sensor
anyone ever get a flashing check engine light while they were driving.
if so what deos it mean?
a/f ratio is all messed up because wires on o2 sensor came loose so it's been running super rich. Car decelerates once in awhile on really hot days. I had the check engine light on for awhile, but this was the first time it ever started flashing.
Anyone have a picture of the o2 sensor and how all the wire plug into it correctly, so i can fix it.
btw, this is greddy set up.
any help would be greatly appreciated!
Old Oct 2, 2003 | 12:34 PM
R6Elmo's Avatar
Default Re: HELP- ? about cel and 02 sensor (98teg)
No idea on the flashing light. Have you checked teh codes on teh ecu to see what it says?
What OBD is your car?
edit.....u have a 98 teg. So that would be OBDII. I only am familiar with obdI 02 sensors, so i can't help you out much at this moment. Which 02 sensor is messedup? Primary...secondary?
Danny
Old Oct 2, 2003 | 04:40 PM
98teg's Avatar
Default Re: HELP- ? about cel and 02 sensor (R6Elmo)
ok found out whats wrong, it's o2 sensor closest to the end of the down pipe. The wires that connect to the grey connector all came loose. If anyone can post a pic of which wire goes where, it would be greatly appreciated.
thanks
Old Oct 2, 2003 | 07:32 PM
98teg's Avatar
fixed the 02 sensor, but what the hell does a flashing cel mean?
Old Oct 2, 2003 | 07:40 PM
Flamenco-T's Avatar
flashing CEL means you have a misfires, check your plugs or better yet replace it if needed.
stan
Old Oct 6, 2003 | 07:41 PM
98teg's Avatar
Default Re: HELP- ? about cel and 02 sensor (Flamenco-T)
cars all fixed now, turns out the wires the injectors came out. i really should soder them instead of using butt connectors. Anyways thanx for everyones help!
wing.jai
26
Sep 10, 2011 05:35 PM
skuba
Engine Management and Tuning
Jan 18, 2010 05:45 PM
thanh4o8
Sep 21, 2009 11:47 PM
