Help me with air filter (Pics)
Old Oct 1, 2003 | 05:48 PM
-iLLuZioN-B18C1's Avatar
Default Help me with air filter (Pics)
there is not much room at all. would a custom k&n filter even fit in here? in the front the radiator fan is blocking it, in the back the block is blocking it, and on left side a hose.
should i get a extender or custom filter. if i do get a custom filter, what size?
ive talked to boosted hybrid, he told me get 5" long and 2.5" inner diameter. the thing is, i measured the compressor and it seems to be almost 3".
Old Oct 1, 2003 | 05:55 PM
GDM Z28's Avatar
Default Re: Help me with air filter (-iLLuZioN-B18C1)
i would say get a extender that puts the filter right up top by the valve cover? and BTW .. what manifold are you running? im looking for a manifold that will let me keep A/C and it looks like urs let u keep a/c. please let me know which mani it is thanx
Old Oct 1, 2003 | 06:06 PM
Quiklude's Avatar
Default Re: Help me with air filter (civicflnum1)
get a slim fan for a local auto parts store, wire it up to "push" and put it in front of the radiator, that will free up all that room where the stock fan is
Old Oct 1, 2003 | 06:51 PM
Adriano's Avatar
Default Re: Help me with air filter (Quiklude)
Do like i did. Get a 3" 90 degree bend pipe, this will make the filter face up . I will try to get a pic.
Old Oct 1, 2003 | 07:05 PM
Default Re: Help me with air filter (brryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brryder &raquo;</TD></TR><TR><TD CLASS="quote">Do like i did. Get a 3" 90 degree bend pipe, this will make the filter face up . I will try to get a pic. </TD></TR></TABLE>
cool, thanks
oh, by the way, for the person who asked its the maxrev manifold
Old Oct 1, 2003 | 07:18 PM
hybrid93SIvic's Avatar
agreed with the 90 degree elbow idea.....put the filter on top of that and it will fit perfect
Old Oct 1, 2003 | 07:32 PM
Honda Hick's Avatar
If you want a cheap ghetto solution get a metal dryer hose from Home Depot. Its very bendable and you can cut it to length. At least get that until you get a permenant solution so you aren't using that T-shirt material, or pantyhose, or whatever the hell yer using now.
Old Oct 1, 2003 | 07:38 PM
egturbo's Avatar
get a slim fan will solve most of ur problems heating problems also
Old Oct 1, 2003 | 07:55 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">should i get a extender or custom filter. if i do get a custom filter, what size?
if its almost 3" then its 2.75" -
http://www.knfilters.com/universal/universal.htm - measure your space and select from there..
http://64.225.76.178/catalog/comp_wheels.html - if you run turbonetics - this should help with size of compressor inlet.
Old Oct 1, 2003 | 08:31 PM
Mr. Softee's Avatar
Default Re: Help me with air filter (vtec.dc2)
3" 90 degree bend w/ a tight radius
sam
Old Oct 1, 2003 | 08:41 PM
SOFLSOL's Avatar
Default Re: Help me with air filter (94goldjungsr)
Just like everyone else said. 90 degree and put a thin filter going straight up.
Old Oct 2, 2003 | 06:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">3" 90 degree bend w/ a tight radius
sam</TD></TR></TABLE>
so where do i get this 3" 90 degree bend? home depot?
Old Oct 2, 2003 | 07:26 AM
ricodemus's Avatar
so where do i get this 3" 90 degree bend? home depot?</TD></TR></TABLE>
JC whitney will have it, but maybe HD too.
Is it a bad thing to put the filter right off of the compressor?
Old Oct 2, 2003 | 07:42 AM
Default Re: Help me with air filter (ricodemus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus &raquo;</TD></TR><TR><TD CLASS="quote">
Is it a bad thing to put the filter right off of the compressor?</TD></TR></TABLE>
no, alot of people do it. jeff(boostedhybrid) actually runs them straight from the compressor as well as his customers' cars.
Old Oct 2, 2003 | 08:07 AM
Ri5e's Avatar
It'll suck in hot air radiating off of the manifold
Old Oct 2, 2003 | 09:14 AM
quikB18B's Avatar
You will need to get something with a tight radius turn, jc whitney stuff will proabably not work, but depends on exactly how much room you have to play with. Pm b18flip he had a link to site that sold tight radius 90 bends ($25-$30). It was short and sweet and looked like no cutting would be invloved
Old Oct 2, 2003 | 10:06 AM
xci_ed6's Avatar
Default Re: Help me with air filter (quikB18B)
maybe a slimmer fan
BTW: my FSAE team flow tested mesh screens (1cm square holes) to flow worse than a K&N air filter.
-Dustin
Old Oct 2, 2003 | 10:14 AM
silverEH2's Avatar
Default Re: Help me with air filter (krustindumm)
are you using an LS tranny with ur setup
Old Oct 2, 2003 | 11:11 AM
Default Re: Help me with air filter (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">are you using an LS tranny with ur setup</TD></TR></TABLE>
nope, complete 94 b18c1 engine and tranny
Old Oct 2, 2003 | 11:54 AM
DaveF's Avatar
i had a slim fan from my local "national auto"(is that an oxi-moron) cost about 75 bucks. than i used my old short-ram genairic intake, cut it to my liking and used it for my turbo inlet...
not a good pic but you get the idea.
Old Oct 2, 2003 | 04:51 PM
Default Re: Help me with air filter (2.2Lcivic)
thanks for the ideas guys
Old Oct 2, 2003 | 05:43 PM
JDEM1's Avatar
i have the same problem with my maxrev kit on my 00 civic si, the stupid cable is in the way and my compressor is so close to the block.. i dont even have space to clamp anything on it besides mesh screen... if anyone can fix my problem and get me a filter on there.. they get 50 bucks
slvrstns2000
Jun 7, 2006 09:25 AM
BuyImports2
Mar 28, 2005 06:05 AM
slammin86
Sep 25, 2004 07:39 PM
CW_97_ITR
Aug 12, 2003 06:19 AM
Mr.DC2TurBo
Dec 12, 2002 06:35 PM
