Take a look at this B16 Block (PICS)
Old Oct 3, 2003 | 08:05 AM
-iLLuZioN-B18C1's Avatar
Default Take a look at this B16 Block (PICS)
I went to a local shop today and saw this b16 block. pretty much it is a blockguard welded in. The thing is, usually i dont see this type of welding/machining. Is this common or different?
How strong does it look to yall??
Old Oct 3, 2003 | 08:20 AM
intekragsr's Avatar
Default Re: Take a look at this B16 Block (-iLLuZioN-B18C1)
Looks like poop
Old Oct 3, 2003 | 08:23 AM
m3bluegsr's Avatar
Default Re: Take a look at this B16 Block (intekragsr)
theres divots in the parts connecting to the sleeves
GSRswapandslow
Guest
Posts: n/a
i'm not really likeing that...
i'm sure the thermal expansion rates are different...in which case i'm sure it'll pull the sleeves out of round before long.
Old Oct 3, 2003 | 08:40 AM
shermanyang's Avatar
Default Re: (GSRswapandslow)
WHOAA!!! that looks like ****!! when i had my blockgaurd welded in, i was right there telling them what to do. i told them to just weld the BG to the block and not the cylinders. they did just that...and it was basically just tack welding it on the edges against the block.
Old Oct 3, 2003 | 10:47 AM
quickergixxer's Avatar
Default Re: (shermanyang)
qoute: WHOAA!!! that looks like ****!! when i had my blockgaurd welded in, i was right there telling them what to do. i told them to just weld the BG to the block and not the cylinders. they did just that...and it was basically just tack welding it on the edges against the block.
dido, sherman who tuned your car in mn and need a 3b tuned
quickergixxer
Old Oct 3, 2003 | 11:30 AM
civictypenos's Avatar
that looks crazy,im no expert but id aggree with the others.the cylinder walls are probably more weak now from the heat of the welder,probably warped since its aluminum.plus looks like it will get some pretty inconsistant cooling from the sloppy welding.but who knows.could work great.
Old Oct 3, 2003 | 11:31 AM
Ri5e's Avatar
Default Re: Take a look at this B16 Block (civictypenos)
nice "block guard"
Old Oct 3, 2003 | 11:36 AM
hpfsi's Avatar
Hmm... if you are going to the trouble to buy a block guard, have it welded in place, deck the block, then have it o-ringed right at the transition from iron to aluminum, why the heck not just have the block resleeved? Although creative, this will never be as strong as full ductile iron sleeves.
Old Oct 3, 2003 | 12:44 PM
turbohappy's Avatar
That is horrid! There's spots where the outside of the cylinder was burnt through! It's not supposed to be welded to the cylinder...
Old Oct 3, 2003 | 01:53 PM
Default Re: Take a look at this B16 Block (turbohappy)
might as well take it to a scrape yard,i didnt see these.
Old Oct 3, 2003 | 05:24 PM
the-anti-crack's Avatar
absolute doo doo
Old Oct 3, 2003 | 05:33 PM
turbo Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">might as well take it to a scrape yard,i didnt see these.
DAAAAAMMMNNN.....I didn't see that. Good eye!
Old Oct 3, 2003 | 08:26 PM
Default Re: Take a look at this B16 Block (the-anti-crack)
okay, i thought it was just me at first, b/c ive seen block with bg's and they look nothing like this. so i guess this block is doomed huh?
Old Oct 3, 2003 | 11:29 PM
SiR Kid's Avatar
New User
I'd trust MINE 100x more than that.... Old skool STR junt, yo.
Old Oct 4, 2003 | 02:00 AM
pornstarSR's Avatar
ok not only did someone PAY to have this done,
but then they are gona THINK it is gona be safer.....that thing looks like it was Stick welded....
so when it overheats and the cylinders warp it was worth it right
90datech
Mid-Atlantic (Sales)
Oct 5, 2010 12:09 PM
cubish
Nov 18, 2006 12:22 PM
D0GMAN
Apr 12, 2005 08:01 PM
infamousALLMTR
Nov 9, 2003 05:53 PM
TedR719
Nov 4, 2002 01:48 PM
