Help Quick BOV Wont Open
Old Oct 3, 2003 | 01:59 PM
Ricey McRicerton's Avatar
Default Help Quick BOV Wont Open
Hey guys..just put a BOV on my Greddy TD04h-15g kit and it wont open. It's a TiAL Bov and it never opens...Ive heard of oiling it, but where should I oil it or what else could I try?? Ive got the line out of the top of it T-d off of my Brake Booster line. Thanks guys!!!
Old Oct 3, 2003 | 02:15 PM
egturbo's Avatar
Default Re: Help Quick BOV Wont Open (Ricey McRicerton)
t it off to ur intake manifold
Old Oct 3, 2003 | 02:17 PM
Default Re: Help Quick BOV Wont Open (egturbo)
It is...the brake booster runs to the intake manifold..I know that it will open off of a brake booster line. It's not even moving a little..can somebody shed some light on this for me?? Where do I grease or oil it??
Old Oct 3, 2003 | 04:25 PM
graphic's Avatar
did you tee before or after the valve inside your break booster line???squeeze around the tube...trust me you will feel it..
Old Oct 3, 2003 | 04:51 PM
mskibbz-T's Avatar
Default Re: Help Quick BOV Wont Open (graphic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">did you tee before or after the valve inside your break booster line???squeeze around the tube...trust me you will feel it..</TD></TR></TABLE>
Try this first
Old Oct 3, 2003 | 05:30 PM
LSiTurbo's Avatar
Default Re: Help Quick BOV Wont Open (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">
Try this first </TD></TR></TABLE>
yea it has to be before the check valve, and also i would recomend another placement for it other than the brake booster line. Why not T it off another regular sized vacuum line?
-Brian W.
Old Oct 3, 2003 | 05:59 PM
Default Re: Help Quick BOV Wont Open (LSiTurbo)
I teed off of the Brake Booster line because "supposidly" its supossed to be more responsive. By before the check valve do you mean more twoards the booster or more twoards the intake mani?? Its very close to the intake mani right now!
Old Oct 3, 2003 | 06:05 PM
boosted_dc2's Avatar
can you push the piston open by hand with the valve of???? are you sure its not adjusted to tight???
Old Oct 3, 2003 | 06:07 PM
Default Re: Help Quick BOV Wont Open (boosted_dc2)
No I cant push it open with my hand..how do I adjust it??
Old Oct 3, 2003 | 06:51 PM
But my check valve is not affecting the BOV....I am on the intake manifold side..so it wouldnt bother the BOVs signal. Can somebody please help me?? All I want is to adjust my TiAL BOV so that I get the coolguy Whoosh sound!!
Old Oct 3, 2003 | 08:52 PM
SOFLSOL's Avatar
Are theyre any type of washers or anything that you can remove spring tension from? Or different springs?
Old Oct 3, 2003 | 09:06 PM
Default Re: Help Quick BOV Wont Open (SOFLSOL)
I dont think so...I havent opened it up yet...was trying to avoid that..but I guess that is first in the plan for tomorrow.
Old Oct 3, 2003 | 10:11 PM
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSiTurbo &raquo;</TD></TR><TR><TD CLASS="quote">
-Brian W.</TD></TR></TABLE>
Brake booster is the best location for it, you get the strongest source of vacuum/boost there... Bigger diameter off the IM.
Old Oct 3, 2003 | 10:12 PM
mskibbz-T's Avatar
Dumb question: Are you boosted? That is, does your boost gauge read boost? Make sure there aren't any IC pipes that are loose and leaking boost, I know it sounds dumb, but this has been the case in a couple other BOV not working threads. Just a thought, don't take offense at it
Old Oct 4, 2003 | 08:32 AM
None taken..yes I am getting into boost...but still no BOV opening...my guage reads positive and my wastegate still "flutters" but the damned thing wont open??? Is there any way to adjust a TiAL???
Old Oct 4, 2003 | 10:08 AM
Okay...thanks for all the help guys..borrowed my friends vaccum pump and his refridgeration guages...ran it up to like 40 in/hg before it finally snapped open..it was just stuck. I put some tefron based lubricant on it and it works like a charm now!! Thanks a ton guys!!
99civichx
Jan 10, 2011 02:52 PM
superslow-oto
Nov 6, 2007 02:42 PM
HondaCutter
Sep 26, 2002 04:20 PM
pelotudo
Aug 26, 2002 10:29 PM
Integra_Boi
Aug 13, 2002 02:10 AM
