SOHC turbo
Old Oct 1, 2003 | 08:28 PM
Jon5240's Avatar
Default SOHC turbo
one quick question, i just invested a nice chunck of cash on a RSR ex-mag exhaust, so can i use that exhaust with a turbo pushing around 9-10 psi? its a 60MM exhaust... thanks -jOn
Old Oct 2, 2003 | 06:31 AM
Jon5240's Avatar
Default Re: SOHC turbo (Jon5240)
ttttttttt
Old Oct 2, 2003 | 06:37 AM
ladysman's Avatar
sure
Old Oct 2, 2003 | 06:58 AM
Jon5240's Avatar
Default Re: SOHC turbo (ladysman)
Are you sure? ive been told i need like minimun 3" piping
Old Oct 2, 2003 | 08:00 AM
M.A.R.C.'s Avatar
3" piping isn't REQUIRED but anything smaller becomes a bottleneck when u start to run higher boost/make more power. i ran 2.5" on my d16 turbo and it was fine... but then again i never ran over 10psi. 3" will shorten spoolup time as well
Old Oct 2, 2003 | 08:13 AM
ladysman's Avatar
Default Re: SOHC turbo (CivicRyda2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">3" piping isn't REQUIRED but anything smaller becomes a bottleneck when u start to run higher boost/make more power. i ran 2.5" on my d16 turbo and it was fine... but then again i never ran over 10psi. 3" will shorten spoolup time as well</TD></TR></TABLE>
Exactly. I say 3" if you are running larger amounts of boost. 1 bar or more is for sure needed if you can afford it. Bigger is almost always better when turboing a car.
Old Oct 2, 2003 | 10:09 AM
5thgencivic's Avatar
Yea, 2.5 will be fine.. I've decided to go 3" on my sohc turbo even though I'll only be running 10lbs for now. Then if I decide to build the motor I won't have to worry about the exhaust.
Old Oct 2, 2003 | 03:01 PM
Distorted's Avatar
Default Re: SOHC turbo (5thgencivic)
Look around at summit for an exhuast swith T or Y pipe. Run your exhaust for daily, and have a remote switch or mechanical switch to open up your exhaust system AT the downpipe before the CAT. This will give you best turbo performance and longevity when your racing or tuning. The exhaust will not only run chances of hurting your power, but it will cause backpressure to your turbo which not only creats wasted energy in heat, it tries to backspool you turbo and damages it over time. THis will allow you to run a legal exhaust and a open downpipe dump for racing/tuning.
reflexgsr-t
Sep 9, 2008 07:10 PM
downeyballz
Dec 28, 2004 02:40 AM
JFG Kevin
Jun 9, 2004 06:24 PM
Rhythm Racer
Mar 3, 2003 10:24 AM
ZC Rex
Oct 15, 2001 05:38 AM
