idle RPMs when setting distributor timing?
Old Oct 2, 2003 | 09:01 PM
keebler65's Avatar
Default idle RPMs when setting distributor timing?
my idle is kind of high...i'm guessing around 800 or 900 rpms. when i set my timing, will this matter? i need it to be set exact and would like to know. hondata says it should be around 600 rpms to be safe. they say if the idle is too high, the timing could be off by as much as 10 degrees is this true? is there such thing as setting the timing when the car is idling too low? if not, maybe i could set the idle to as low as it goes and do the timing from there.
Old Oct 2, 2003 | 09:04 PM
twkdCD595's Avatar
Default Re: idle RPMs when setting distributor timing? (keebler65)
bummer some people cannot even idle as low as 600... I never thought it would make such an issue.
mine car idled stock at like 800.
Old Oct 2, 2003 | 09:14 PM
30psi Teg's Avatar
Have you tried unpluging the TPS sensor with the car at idle this can help drop the RPM. I havnt had to much trouble adjusting around 700 to 800 though.
xxxmikenicexxx
Oct 11, 2009 01:03 PM
924doorEG
Sep 27, 2007 03:06 PM
civickiller
Feb 15, 2007 12:38 AM
ludedudesi
Feb 9, 2003 03:09 PM
non-VTEC
Jan 27, 2002 12:15 PM
