AEM UEGO Wideband mounting in an Integra?
Re: AEM UEGO Wideband mounting in an Integra? (integra-modder)
i hooked up the wires to the orignal wires that went to the stock o2 sensor and zip tid the box to one of the a/c lines by the shock tower
Re: AEM UEGO Wideband mounting in an Integra? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">i hooked up the wires to the orignal wires that went to the stock o2 sensor and zip tid the box to one of the a/c lines by the shock tower</TD></TR></TABLE>
Do you have pictures?
Where are you from?
Where are you from?
Moderator in Chief
I snagged myself another connector from the stock O2 sensor pigtail and I plan to solder that onto the 4 wire comming off the AEM WB controller harness. That way I can easily tap into the original oxygen sensor harness. This also would allow me to switch back and forth between the stock and wideband sensors if I need to as nothing is permanent. Hit me up on AIM, ill try to get some pics soon.
Re: AEM UEGO Wideband mounting in an Integra? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">I snagged myself another connector from the stock O2 sensor pigtail and I plan to solder that onto the 4 wire comming off the AEM WB controller harness. That way I can easily tap into the original oxygen sensor harness. This also would allow me to switch back and forth between the stock and wideband sensors if I need to as nothing is permanent. Hit me up on AIM, ill try to get some pics soon.</TD></TR></TABLE>
I havent seen the kit yet, im placing the order today so I will see what I get in about a week.
How does this setup connect? Where did you mount the unit itself and did you run a seperate connector for the wideband?
"a picture is worth a thousand words..."
<U> </U>
<U> </U>
Moderator in Chief
If you want, thats what the directions say. Find the 4 wire harness and splice into it. I just thought a nice connector would make the job much cleaner, and reversable if needed!
Im still intimidated by wiring. Boo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">If you want, thats what the directions say. Find the 4 wire harness and splice into it. I just thought a nice connector would make the job much cleaner, and reversable if needed!
Im still intimidated by wiring. Boo</TD></TR></TABLE>
haha...wiring intimidation.... I did my own alarm install...check this out, and this is about only half...
vladd
05-19-2007 02:25 PM
