Clutch problem.. need help asap
Old Oct 4, 2003 | 03:26 PM
Rpc07's Avatar
Default Clutch problem.. need help asap
My clutch is slipping like no other. There is only 2000 miles on my motor/clutch. i just had the motor totally built for turbo and put it in. the clutch is an action 2md pressure plate with a ACT 6 puck disc. I do have pressure in my pedal so I know thats not the problem but when i try and drive it or give it gas or anything it wont grab at all. it just slips and the RPM revs like as if it were in neutral almost. the car will move but very slowly.
i am not sure if it is the flywheel or the disc. i dont think its the disc because its a brand new disc and there is like no way it could of gone out after 2k miles. the flywheel i am using is a fydanza 7.4lb flywheel and i just had it resurfaced i didnt know i was suposed to buy a new insert and have that put in instead of getting it resurfaced. so that might be the problem but i have no clue. any ideas as to what it is. thanks
ryan
Old Oct 4, 2003 | 03:47 PM
Rpc07's Avatar
Default Re: Clutch problem.. need help asap (Rpc07)
bumpz0r
Old Oct 4, 2003 | 03:50 PM
boostsohfast's Avatar
Did you check the slave cylinder to see if it fully returns? I've seen quite a few of them hang up.
Old Oct 4, 2003 | 05:03 PM
Rpc07's Avatar
Default Re: Clutch problem.. need help asap (boostsohfast)
yeah i did and its still full...
Old Oct 4, 2003 | 05:08 PM
92JDMSiR's Avatar
aiilar prlem happenned to me once. it turned ut it was my flywheel. the flywheel was cu to deep and the pressure plate had to push the disc t fa to gab so it made te clutch slip. Iw ould try that first befor you go and buy another clutch
Old Oct 4, 2003 | 05:24 PM
Rpc07's Avatar
Default Re: Clutch problem.. need help asap (92JDMSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92JDMSiR &raquo;</TD></TR><TR><TD CLASS="quote">aiilar prlem happenned to me once. it turned ut it was my flywheel. the flywheel was cu to deep and the pressure plate had to push the disc t fa to gab so it made te clutch slip. Iw ould try that first befor you go and buy another clutch</TD></TR></TABLE>
thats what i was thinking was the problem... i do have my stock flywheel here so i think i am going to change out my flywheels and see if that solves the problem. thanks
anyone else have any ideas
Old Oct 4, 2003 | 07:40 PM
Rpc07's Avatar
i just went and drove my car again to see if anything else happened with the problem. i noticed that the clutch doesn slip that much at all anymore but i have lost a lot of pressure in the pedal.
what could be happening here?
ryan
trus01d1er
Nov 12, 2006 11:03 PM
Chiller
Apr 10, 2005 10:52 PM
tallblondkid
Aug 19, 2004 10:03 AM
gsf4726
Jan 15, 2004 10:00 AM
97accordex
Jul 23, 2002 05:24 PM
