JDM ITR
Old Oct 3, 2003 | 10:23 AM
not133t's Avatar
Default JDM ITR
I have a 98 spec JDM ITR motor in my 1999 GSR, i want to do forced induction but dont want to touch the motor, plus i have limited amount of money, im tryin to get some suggestions
Old Oct 3, 2003 | 10:30 AM
stierhund's Avatar
Default Re: JDM ITR (not133t)
You made a good move comin here because I would suggest getting input on building your own kit. Find out what components you need here and then find someone that you know can put it together properly.
Right off I would recommend to keep the longevity of your motor in mind. Your motors compression is really high for forced induction, and I would recommend lower compression pistons that are stronger than stock. Unless you wanna make a good deal of power on high compression pistons that could destroy your motor if its not built properly.
Go with a smaller turbo than normal unless you wanna run high boost. A turbo with high effeciency at providing 10-12 psi on your motor would be great if you had the car tuned good.
Old Oct 3, 2003 | 11:19 AM
DaveF's Avatar
Default Re: JDM ITR (stierhund)
get an inline pro headasket to lower your compresion.
http://www.inlinepro.com
Scubster
Dec 16, 2004 10:54 PM
Chubz
Sep 6, 2004 02:25 PM
TEAM562racing
Oct 15, 2003 01:55 PM
Rratedcivichatch
28
Sep 23, 2002 07:28 PM
01-0720
Apr 11, 2002 11:35 PM
