built d16a6 turbo potential?
Old Oct 4, 2003 | 06:51 PM
jessevtec's Avatar
Default built d16a6 turbo potential?
well for my next project i want to build a sohc turbo, whats the potential with it?as in using the hf manifold and eagle rods with low comp je pistons? what type of power would it put out with the right turbo? how much psi would be possible? what quarter mile times in a crx with this setup will be possible? and what would be the best tranny for a turbo sohc non vtec, for dragging?
Old Oct 4, 2003 | 09:09 PM
xci_ed6's Avatar
Default Re: built d16a6 turbo potential? (jessevtec)
NO HF MANIFOLD! Otherwise I'd go with the B16/Supra rod/piston combo and throw 15psi er so at it.
Z6 has seen 305whp on stock internals, the A6 is rumored to have a tougher bottom end.
You should do a search this stuff has been covered alot.
-Dustin
Old Oct 5, 2003 | 03:33 AM
jessevtec's Avatar
what if i start with the HF mani and then after everything is hooked up get a better manifold?
hatchinprogress
Dec 23, 2005 11:13 AM
89 CRX SI
Apr 8, 2002 09:15 PM
