SMC and JRSC
Old Oct 2, 2003 | 11:39 AM
1strdko's Avatar
Default SMC and JRSC
Where is the map sensor suppose to be located? Anybody have pictures?
Old Oct 2, 2003 | 12:20 PM
GreddySi99's Avatar
Default Re: SMC and JRSC (1strdko)
locate the map so it sees vacuum and boost thats it
Old Oct 2, 2003 | 12:28 PM
keebler65's Avatar
Default Re: SMC and JRSC (intercooledJRSC)
it should be hooked up to the manifold itself. there are two ports on the JR manifold pictured below....just to the left of the intake air temp sensor but to the right of the vacuum source for the brake booster:
Old Oct 2, 2003 | 02:30 PM
1strdko's Avatar
I have mine sitting on the TB. It use to be off the TB before the NEW B18 bottom was installed.
Old Oct 2, 2003 | 02:35 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1strdko &raquo;</TD></TR><TR><TD CLASS="quote">I have mine sitting on the TB. It use to be off the TB before the NEW B18 bottom was installed.</TD></TR></TABLE>
for a JRSC using an SMC, the map sensor MUST be located after the blower.
Old Oct 2, 2003 | 08:45 PM
1strdko's Avatar
Default Re: SMC and JRSC (keebler65)
What did you use to cover the opening in the TB?
Old Oct 2, 2003 | 08:56 PM
keebler65's Avatar
well mine is a B16A, so it never was mounted on the TB. however i've heard of people in your situation that just cut a small piece of metal out in the shape of the opening and screw it on. maybe use some hondabond on the mating surfaces to seal it good.
sixfourkiller
Jan 3, 2011 09:36 AM
IamVtec
Jan 21, 2007 08:51 PM
hondaeg8
Jul 29, 2005 07:41 PM
93supercoupe
Feb 10, 2005 02:29 PM
JRciv
Dec 15, 2004 10:08 PM
