backfires
Old Oct 1, 2003 | 05:45 PM
iluvdrt's Avatar
Default backfires
ok i have a ea82t turbo subaru wagon(i know im at the wrong site, but people here are smart) any way when i am getting on my car after i shift it back fires into the turbo, will this hurt anything. also my up pipe has a big exhaust leak in it, now i know this will hurt the spooling but but is it possible that because its losing the back pressure that that is whats making it back fire.
ps, ive already done a complete tune up and adjusted the timing to manufacturer recomendations. also i run 93 octane gas.
Old Oct 1, 2003 | 06:02 PM
ross1459's Avatar
Default Re: backfires (iluvdrt)
i've heard people claim that this keeps the turbo spooled or helps the turbo spool faster... idk if it would hurt anything.
Old Oct 1, 2003 | 06:33 PM
92HB_HB's Avatar
Default Re: backfires (ross1459)
i noticed that after my car was tuned, i tend to hear my engine backfiring from the exhaust when i shift gears normally.... i thought this was unusual because it never happened in my last setup last yr....
Old Oct 1, 2003 | 07:39 PM
iluvdrt's Avatar
well i just donty want to hurt the turbo, but i didnt think it would really hurt anything. keep them coming i would like to now.
Old Oct 1, 2003 | 07:48 PM
Ricey McRicerton's Avatar
Well Ill be damned...an HT member from my hometown...hows Jville treating you man?
Old Oct 1, 2003 | 08:25 PM
iluvdrt's Avatar
j-actionville, isnt so bad if you can get past the egotistical marines. its in desparate need of some more entertainment things though. we did just get a bitchin new movie theater though. 93preludevtec lives here too, as im sure a few members do.
Old Oct 2, 2003 | 11:31 AM
iluvdrt's Avatar
bump
Old Oct 3, 2003 | 10:05 AM
vtekthis's Avatar
youmean afterfiring, backfiring is through the intake when the car is running to lean
Old Oct 3, 2003 | 10:52 AM
the1eddins's Avatar
Default Re: (vtekthis)
i would say that the leak in your up pipe introduces fresh air into the exhaust stream and makes it easier to ignite. and the whole turbo thing, yes it could damage the turbo after a while doing it. rally racers use a system that injects a little more fuel into the engine whenever they shift, and that causes a fireball to go across the turbine nad keep the turbo spooled, which is why if you ever watch the wrc's you can always see a little fire ball each time they shift, they call it the pop-pop system. it is known under harsh situations to melt the turbine cause it gets so hot, but it is unlikely that it would happen to you. but over time it could kill your thrust bearing. but i wouldnt worry about it...just fix your up pipe. that alone will make your car feel alot peppier just from the lack of exhaust making it to the turbo.
Jul 24, 2009 12:29 PM
chuckles2
Mar 13, 2005 01:22 AM
Hatch It
25
Aug 26, 2004 09:44 AM
cr-x si
Feb 6, 2003 04:51 PM
John
Apr 26, 2002 03:56 PM
