Making your own IC piping
Old Oct 2, 2003 | 12:14 PM
-Trinitron-'s Avatar
Default Making your own IC piping
So for all the guys that make thier own piping, do you get the ends beaded to prevent the couplings from blowing off under boost? Or is that really an issue?
Old Oct 2, 2003 | 12:30 PM
99integralsturbo's Avatar
Default Re: Making your own IC piping (-TRINiTRON-)
it is a good idea to do it I have one pipe that isnt beaded and it comes off evert once in a while, i am just gonna have the guy that does all my stuff put a bead of weld around the pipe
Hope this answers your question
Old Oct 2, 2003 | 12:32 PM
R6Elmo's Avatar
Default Re: Making your own IC piping (99integralsturbo)
Yup...bead the weld. If you don't have a welder...a more ghetto way to do it is this:
Drill a small hole, and put a little rounded head screw though it. It'll help to keep the hoses from blowing off.
Worse case scenario, purchase t-bolt clamps, you'll never have a problem.
Old Oct 2, 2003 | 12:33 PM
Boosted Gsr Hatch's Avatar
that works but the welded bead came off on my buddies car and went into the turbo impeller blades. there is a bead maker that presses a ream into the pipe. xoticmotorsports.com did mine cause there close to my house. they might be able to point you in the right direction.
Old Oct 2, 2003 | 12:42 PM
quikB18B's Avatar
Default Re: Making your own IC piping (Boosted Gsr Hatch)
I'm using t-bolt turbo clamps and havent had any problems
I have 4 left over if anyone is interested, they are for 2" piping.
Old Oct 2, 2003 | 12:44 PM
Default Re: Making your own IC piping (R6Elmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">
Worse case scenario, purchase t-bolt clamps, you'll never have a problem.</TD></TR></TABLE>
yeah i have T-bolt clamps on my one pipe that has no bead for now and it hasnt come off yet, they usually go for around $4 a piece but they are worth it
Old Oct 3, 2003 | 04:26 AM
BROOD's Avatar
Bead rolling the pipes is a good idea, it can't hurt. Usually cost $10-20 per pipe or $360 if you want to buy your own bead roller.
Bead rolled pipes with regular worm gear clamps hold up pretty well hose pop-off. Usually there is no need for T-bolts.
Old Oct 3, 2003 | 06:46 AM
scttydb411's Avatar
i guess i'm lucky. i use worm clamps. i just cleaned any traces of oil off the pipes and then filed the ends where the silicone couplers connect to rough up the surface and then tightened the **** out of them.
Old Oct 3, 2003 | 08:12 AM
m3bluegsr's Avatar
Default Re: (scttydb411)
i havent had a problem my pipes yet. i bought this hose thats heavy duty ish from napa and used that as my couplers. It was a bitch to get over the pipes but it isnt going ne where.
Old Oct 3, 2003 | 11:17 AM
So can most muffler shops bead roll the pipes? Or should I just try welding a bead around the edge of each joint?
Old Oct 3, 2003 | 12:25 PM
JOSEPH's Avatar
if you have access to a welder, just bead weld it. thats what I did.
killacam661
Nov 24, 2008 10:46 PM
LilCivic04
Apr 22, 2005 08:07 PM
Bictorious
Feb 19, 2004 08:44 AM
jthelman
Feb 15, 2003 11:32 PM
redteg1
Jan 23, 2002 08:51 PM
