D15 Turbo Q's
Old Sep 12, 2004 | 02:10 PM
GotMurph's Avatar
Default D15 Turbo Q's
I have read alot of the topics on this and just wanted to get a few things straight. As I understand it I can use the d15 in my 94civic dx, but install another d series head such as z6, y8,or a6. What would be the best turbo for the d15? Also what can I expect from the motor hp wise with just say a z6 head, 8psi with a small turbo?? Any help is appreciated as I know this is a widely talked about topic.. Also any people that I might be able to talk or email with about a d15 setup. I have the loot the tools and the places to get the parts.. Just need a direction. Thanks
Old Sep 12, 2004 | 03:40 PM
ej1 pilot's Avatar
Default Re: D15 Turbo Q's (GotMurph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GotMurph &raquo;</TD></TR><TR><TD CLASS="quote">I know this is a widely talked about topic.. </TD></TR></TABLE>
exactly...use the search button...
hint: search user eg6turbo
Old Sep 12, 2004 | 03:57 PM
USDM 4G VTEC's Avatar
too much to write
aim me or something ill give u some tips
Old Sep 12, 2004 | 08:36 PM
GotMurph's Avatar
Default Re: D15 Turbo Q's (USDM 4G VTEC)
Will def be in touch.. I was looking at some links on the RHB5 and greddy turbo's and taking some notes.. I have found z6,y8 heads for free from a friend. Im just looking to speed up this slow d15, im game for bolt-ons but as far as changing rods and pisons that I dont have the time for.. To many toys already I have projects goin on.
Old Sep 12, 2004 | 08:56 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
just get a greddy or apexi
Old Sep 12, 2004 | 09:01 PM
plusONE jboy's Avatar
well since that swap is so cheap just build up the block and run lots of boost.
Old Sep 13, 2004 | 06:14 PM
GotMurph's Avatar
Default Re: (j boy)
I could easily buy the greddy setup but if i were to spend thast kind of money i would rather spend my money wisely and goto a bigger motor.. I'm getting the y8 head, and have a guy getting me all the parts from a 1g DSM (turbo, BOV, injectors). How much nos can I throw on this, or would it be worthless. Do they sell stronger rods for a 1.5? Because through some research these past few days going to a 1.6 piston/rod setup seems to be a lil safer. Also I have seen topics posted about the dx trannies being to long and that an EX would be better, I have an ex tranny avaliable to me. Engine has 116k.
Old Sep 13, 2004 | 06:33 PM
GotMurph's Avatar
Default Re: (GotMurph)
Forgot to ask.. I take it I lose AC when doin a turbo?
Old Sep 13, 2004 | 07:15 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Depends on the manifold you purchase, for the most part I have seen a lot of D series A/C compatible manifolds.
Here are few D16 turbo searches:
https://honda-tech.com/zerothread?id=278462
https://honda-tech.com/zerothread?id=483444
Old Sep 14, 2004 | 09:08 AM
GotMurph's Avatar
Default Re: (INVALID)
Ok what about NOS on that d15 block? Does it do more harm then good? Also what are a decent set of pistons and rods.. OEM or aftermarket?
Old Sep 14, 2004 | 09:28 AM
nonvtecD's Avatar
Y8 head? Dont raise your compression for like 15 horsepower if you're going to go turbo.
Old Sep 14, 2004 | 10:01 AM
GotMurph's Avatar
Default Re: (D15B7turbo)
What head would you suggest? because I have the y8 and z6 sitting at my shop right now.
Old Sep 14, 2004 | 10:48 AM
nonvtecD's Avatar
stock head, leave it stock compression, research Uberdata (www.ecimulti.org/uberdata) and boost away.
Old Sep 14, 2004 | 07:32 PM
GotMurph's Avatar
well i have 2 complete y8, z6 heads, question is what setup is gonna make me the most power with dsm parts (td05h, 450inj, 1g BOV). I will have the STD by fri, used for $25. I have some1 already with the uberdata so that I can remap either the vtec or dx stock computer. As i Understood from readin these posts that a change to the y8 would result in more compression but I would also have a larger intake manifold and still would be able to throw good number at the 5.5 to 7 psi mark. what kind of numbers are ypu pushing with the d15 setup? also waht about nos? does it do more harm them good? or should i not have to worry because of the quik spooling turbo?
Old Sep 14, 2004 | 07:36 PM
nonvtecD's Avatar
You can use the intake manifold without using the whole head. You're doing this all yourself or what?
Old Sep 15, 2004 | 09:58 AM
GotMurph's Avatar
yes to the work... only way I'll know it'll get done right. I have a month before I can commit to this project anyway, and hopefully in that time I'll be able to actually see a kit done this way first hand. D15B where you located?
Old Sep 16, 2004 | 01:51 PM
GotMurph's Avatar
Anyone else with comments to these parts..
td05h turbo
std manifold
dsm 450 injectors and 1g blowoff
z6 and y8 heads
I havent driven a d series that has been boosted, some say 190-220 with just turbo setup leaving the stock head, all this work is for a 94 civic dx hatch. Will be doin pulleys, ex tranny, eliminating a/c.. What about a cam gear or even nos, talk to me fella's.
Jay_Mills
Mar 31, 2012 04:57 AM
ben222
Aug 29, 2007 06:11 PM
boostedeg22
Feb 3, 2006 09:50 AM
JDM_EjONE
Jan 3, 2006 03:03 PM
SunkistRex
May 10, 2004 03:15 AM
