jg manifold question
Old Sep 10, 2004 | 04:57 PM
drvfast's Avatar
Default jg manifold question
I have a jg intake manifold on a b16 in a crx. I am having a problem with the throttle cable. Does jg make a cable or a bracket that I can use to fit the throttle cable correctly. Thanks
Old Sep 10, 2004 | 08:06 PM
drvfast's Avatar
Default Re: jg manifold question (drvfast)
ttt
Old Sep 13, 2004 | 04:13 AM
drvfast's Avatar
bump
Old Sep 13, 2004 | 04:46 AM
dasher's Avatar
no ... you have to make one yourself
Old Sep 13, 2004 | 05:23 AM
Blurex's Avatar
I have a crx b16 with edelbrock mani and it would not open all the way and the cable rubbed the manifold. So i tried making my own throttle cable bracket (that was taller), but it would still not fully open the throttle but, it did allow the cable to clear and not rub the manifold. I had to get the throttle wheel off a b18a integra (90-91) (the dia was smaller than the 1st gen b16a). My first gen b16a throttle body wheel was larger and at the end of the wheel it has a longer leg. So i figured i need a throttle wheel with a smaller diameter. after installing the integra wheel it works fine now, and the throttle fully opens. The springs were not that bad to ge back on, i just used some needle nose. I have some pic but i don't know how to post them. I will email them to you if you interested.
Old Sep 13, 2004 | 07:34 AM
drvfast's Avatar
Default Re: jg manifold question (Blurex)
pmed
autoxthis
11
Aug 9, 2008 11:52 AM
TurBoTeG
Jan 21, 2006 03:31 PM
Autoworks
Mar 10, 2005 04:19 PM
mustbenu
Dec 30, 2003 03:38 PM
SIReg9
Oct 9, 2003 08:16 PM
