power loss
Old Sep 9, 2004 | 04:00 PM
zseeanz's Avatar
Default power loss
I have been boosting now for awhile at 9psi. I haven't been able to keep the wheels from spinning at wot in 1st and second gears. Just the past couple days and I've noticed I can't even do it in 1st gear let alone 2nd. The boost is there just not the power. I've changed plugs, and fuel filter so far. The only thing I could think of is my carsound cat. I've only had it for about 4 months but I heard the go bad alot. Could the cat be causeing this? I haven't done a compression test yet but I'm not burning oil, no smoke, not over-heating, just enough power loss where my tires won't break loose. Could it be my clutch? I still have a stock clutch but everything seems to be ok with that.
Old Sep 9, 2004 | 04:12 PM
Ri5e's Avatar
Default Re: power loss (zseeanz)
Is smoke coming out of your valve cover breather hole or oil dipstick hole?
Old Sep 9, 2004 | 04:17 PM
zseeanz's Avatar
Default Re: power loss (BG Boost)
haven't noticed any smoke at all.
Old Sep 9, 2004 | 04:18 PM
shadow103rd's Avatar
My aim is the clutch....The thing is probably beat....I had the same problem wiith my clutch....However I would do a compression test and verify the health of the motor
Jon
Old Sep 9, 2004 | 04:19 PM
zseeanz's Avatar
Default Re: power loss (shadow103rd)
thanx for that. I have a spec stage 3 cluth on order right now. I'm doing a compression check next week.
griff12
Jul 17, 2013 11:21 AM
Cypher0117
11
May 30, 2006 06:57 PM
95IntegraRS
May 28, 2006 11:24 AM
BryanPendleton
Dec 21, 2004 06:27 AM
servion
Mar 2, 2004 03:59 PM
