I need your opinion
Old Sep 11, 2004 | 08:01 PM
tegsp's Avatar
Default I need your opinion
i have got a 92 integra ls and it has 177,000 miles on it. After i finish installing the suspension setup i want to put in, I am either going to buy a b18b or rebuild the motor, and eventually boost. I cant decide which route to take. Which would be cheapest(or better for the money)? When I do boost, it is going to be a daily driver and probably wont be running more then 12 psi. I am on a budget here and I would like to spend no more then 2-3000 on the motor. Thanks for any replies.
Old Sep 11, 2004 | 08:28 PM
tegsp's Avatar
Default Re: I need your opinion (tegsp)
any opinions?
Old Sep 11, 2004 | 08:41 PM
toolowsol's Avatar
build up your current motor, I would say pistons+rods, and basic rebuild would be able to handle 12psi or so on most turbos
Old Sep 11, 2004 | 09:08 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsp &raquo;</TD></TR><TR><TD CLASS="quote">i have got a 92 integra ls and it has 177,000 miles on it. After i finish installing the suspension setup i want to put in, I am either going to buy a b18b or rebuild the motor, and eventually boost. I cant decide which route to take. Which would be cheapest(or better for the money)? When I do boost, it is going to be a daily driver and probably wont be running more then 12 psi. I am on a budget here and I would like to spend no more then 2-3000 on the motor. Thanks for any replies.</TD></TR></TABLE>
If you have 177k miles I would recomend a refesh (rebuild) of the motor then boost it. Or you could boost it (if it's burning oil it'll just get worse) and save up to rebuild...
Either way 170+k + boost isn't good for long...........
wait boost OR b18b motor?
Get the b18.....177k is a lot of miles
Old Sep 12, 2004 | 09:55 AM
tegsp's Avatar
Default Re: I need your opinion (b16ahybrid)
would doing a rebuild cost more then getting a new b18b?
Old Sep 12, 2004 | 10:01 AM
Ckjeepin's Avatar
Even if not the rebuild will not make the motor perfect again.. Unless you get it stripped down and hot tanked and resurface and all kinds of crap..
Old Sep 12, 2004 | 10:15 AM
tegsp's Avatar
Default Re: I need your opinion (Ckjeepin)
That is true, I think im going to get a used b18b and go with that.
99JDMLSBOOST
May 4, 2009 05:40 PM
CuzzinDohc
Jan 31, 2008 05:56 AM
94c1v1cex
Nov 22, 2007 09:13 AM
allmotrjdm
Mar 8, 2004 04:33 AM
integracivic94
Jun 6, 2003 04:58 PM
