do i need a HP or LP fuel pump for my setup?
Old 09-09-2004, 10:03 AM
yusoslo's Avatar
Default do i need a HP or LP fuel pump for my setup?
I am looking at a walbro 255 and I am using 450 dsm injectors and uberdata.
which fuel pump should I order?
this is for a d16z6 12psi with a t3 .42 ar
Old 09-09-2004, 10:17 AM
twkdCD595's Avatar
Default Re: do i need a HP or LP fuel pump for my setup? (yusoslo)
personally I would go with the hp and have the extra room to grow... otherwise either pump should be a-ok for your setup.
Old 09-09-2004, 10:38 AM
Rod.'s Avatar
Default Re: do i need a HP or LP fuel pump for my setup? (twkdCD595)
go with hp..especially with 12psi
Old 09-09-2004, 10:39 AM
yusoslo's Avatar
Default Re: do i need a HP or LP fuel pump for my setup? (redturbocivic)
wont this pose a problem with the stock fpr????
i thought hp was for FMU's and that kind of stuff
Old 09-09-2004, 12:33 PM
notoriousB's Avatar
I use the LP w/ DSM 450's - you shouldn't need to run higher than stock fuel pressures with that setup.
You may have idling issues if you use the HP due to too much fuel pressure with the stock FPR.
Old 09-09-2004, 01:48 PM
yusoslo's Avatar
Default Re: do i need a HP or LP fuel pump for my setup? (notoriousB)
thanks for the help
AZNracerx1989
09-18-2005 08:21 PM
M.K.C.
11-17-2003 10:43 AM
soundman
09-12-2003 03:05 PM
1tyme
10-22-2002 12:36 PM
Quick Reply: do i need a HP or LP fuel pump for my setup?
