B18a1 turbo setup help!! I SEARCHED!!
I did the search and didn't find anything.. I am going to boost about 8 pounds of boost usin an IHI RHB6 turbo.. I think it's equivilent to a T28.. anyways, I already have the manifold and down pipe.. I was just wondering if anyone has the part numbers for the Oil feed lines and for the Oil return line.. I already have the flange attached for the oil return on the turbo, so all I need are the type of lines and fittings to T off the oil pressure sensor and stuff... Also, I was wondering if I will need larger injectors... I already have an SAFC, do I still need an FMU??? What part number should I get for the 2 step colder plugs?? This set up is going to be on a 1990 civic hatchback w/ an OBD-1 b18a LS motor... THANKS!!
Mark
Mark
Re: B18a1 turbo setup help!! I SEARCHED!! (MarkAngelo)
This is for the oil feed to T from the firewall, NOT the back of the block.
Get your oil return from FLamenco-T
http://www.fast-turbo.com
