92 ls turbo how do I hook up the map sensor with the check valve?
as stated. WE put the bottom of the map sensor port inline with a vacuum source from the manifold the check valve oriented so you can blow air into it, just suck. Is this right???
Re: 92 ls turbo how do I hook up the map sensor with the check valve? (yusoslo)
Your question is kinda confusing.
You shouldn't be able to blow air into it but you should be able to suck air from the intake manifold
Re: 92 ls turbo how do I hook up the map sensor with the check valve? (BG Boost)
thats how we have it set up. the map sensor on a 92 ls intergra is on the firewall not the throttle body.
the check valve is setup so you cant blow into the map sensor , but a vacuum is allowed to it. (or sucking from the intake mani like you said. but we got a check engine light for some reason and that is the only fuel. electronic change we made.
eg93LS
06-10-2009 08:51 PM
