Please help with BOV.
Old Sep 12, 2004 | 11:55 AM
NotUrAvgSi's Avatar
Default Please help with BOV.
Just installed the Full-Race turbo kit last night and we have noticed that the BOV is open at idle. My buddy has the same BOV (50mm Tial) and his is closed at idle. Now im not sure if my is supposed to be open because its at the end of the intercooler or do i have a vacum problem. Full-Race guys please help let me know what your BOV does. Thanks
Old Sep 12, 2004 | 12:02 PM
toolowsol's Avatar
Default Re: Please help with BOV. (NotUrAvgSi)
so adjust it until it remains closed at idle....
Old Sep 13, 2004 | 10:57 AM
utahbmx's Avatar
Default Re: Please help with BOV. (toolowsol)
how do you adjust a blow off valve? there is no adjustments on it. just the vacume port. On another note Boris chage your damn avatar beeoch
Old Sep 13, 2004 | 02:13 PM
lanojp1's Avatar
it SHOULD close once you apply throttle to it...because in theory if you think about it, the BOV opens when you are off the throttle to release pressure, so at idle you are off the throttle causing it to remain open...
Old Sep 13, 2004 | 02:18 PM
Full-Race Henry's Avatar
At Idle, it should be remained closed. It should only open when it feels vac, but should not remain open. what vac source are you using?
Old Sep 13, 2004 | 02:26 PM
MooreBoost's Avatar
Default Re: Please help with BOV. (Full-Race Henry)
A BOV needs a good vacuum source and pressure surge to open up. At all other times it should be closed. There should be a spring inside the wastegate, you may need to take it out and strech it.
Old Sep 14, 2004 | 09:57 AM
NotUrAvgSi's Avatar
we used the brake booster
Old Sep 14, 2004 | 09:58 AM
FOrSfEd's Avatar
Default Re: (NotUrAvgSi)
how can you tell the BOV is open. The brake booster should be a good vac source.
Old Sep 14, 2004 | 10:06 AM
NotUrAvgSi's Avatar
because the spring is not closed on idle. when you hit the gas pedal it closes.
Old Sep 14, 2004 | 10:37 AM
utahbmx's Avatar
Default Re: (FOrSfEd)
You can actuall see the open valve....then when the throtle is pressed at all it closes....I runs and holds boost, but we just thought it was weird since I have the same BOV (tial) and it always remains closed at idle. Could it have anything to do with it being mounted on the intercooler instead of the upper charge pipe?? We thought there could be some pressure difference that was effecting it....or is the brake booster line to big? It seems the t fitting supplied with the kit were ment to be installed there since they were so large.
vladd
Jan 11, 2007 11:06 AM
eg:R
Sep 17, 2006 06:47 PM
EFbomb
Sep 3, 2004 01:08 PM
_Endless_
Jul 4, 2003 10:56 AM
echo999
May 14, 2002 08:54 PM
