Which is the best aftermarket b series oil pan?
just like the topic says, just wondering what the best aftermarket b series aluminum pan is, i remember people saying a few of them sucked because the oil return bungs sat below the oil level and kept blowing turbos, but i know there are a bunch of new companies offering the pans.
TIA
Jason
TIA
Jason
Re: Which is the best aftermarket b series oil pan? (Code Blue)
<-- Moroso oil pan. I'm using pan #20901 and the oil pump pickup is #24011.
Modified by EM1 MIKE at 12:31 PM 9/12/2004
Re: Which is the best aftermarket b series oil pan? (EM1 MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1 MIKE »</TD></TR><TR><TD CLASS="quote"><-- Moroso oil pan. I'm using pan #20901 and the oil pump pickup is #24011.
Modified by EM1 MIKE at 12:31 PM 9/12/2004</TD></TR></TABLE>
any problems with the oil? i heard horror stories about moroso pans and blowing turbo seals because the oil drain bung was too low
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue »</TD></TR><TR><TD CLASS="quote">
any problems with the oil? i heard horror stories about moroso pans and blowing turbo seals because the oil drain bung was too low</TD></TR></TABLE>
that's only for people that use the low plug on the front, there is a plug at the top of the pan that is perfect for turbo drain.
Re: Which is the best aftermarket b series oil pan? (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 »</TD></TR><TR><TD CLASS="quote">Any particular reason you want an aluminum oil pan?
They tend to dent easy
even in the summer months, rust hurts in upstate ny.
plus, im going to have a 4 point brace underneith and that will be the first thing to scratch, a cheap 40 dollar investment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever »</TD></TR><TR><TD CLASS="quote">
that's only for people that use the low plug on the front, there is a plug at the top of the pan that is perfect for turbo drain.</TD></TR></TABLE>
ahh ok that i didn't know, thanks
