Best way to Get Oil feed
Hey I was wondering what is the best way to get Oil into your turbo. Is it better to just attatch the line to the back of the block, or get a special oil filter attatchment that will gives u a nipple to attatch to?
Thanks
Thanks
Re: Best way to Get Oil feed (g2_boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_boosted »</TD></TR><TR><TD CLASS="quote">Hey I was wondering what is the best way to get Oil into your turbo. Is it better to just attatch the line to the back of the block, or get a special oil filter attatchment that will gives u a nipple to attatch to?
Thanks</TD></TR></TABLE>
I think either way would work fairly well. I, myself, am using the stock oil pressure sensor location for oil feed. If you choose to go that route.. just don't attach a 'T' on there and hook up your stock oil pressure sensor and oil feed line to it because it'll put some stress onto that part of that block and may break it. Instead run the oil line out toward to firewall, then into the 'T' and secure the 'T' somewhere.
