2000 gsr greddy turbo overboosting
2000 gsr turbo wastegate ???????
I have a 2000 integra gsr w/ the greddy turbo kit. i built the motor and now have to figure out how to get my greddy boost controller and my waste gate to work properly or at least the waste gate. the car spools up to 20 psi and the motor is not built that strong nor is there enough fuel to run that psi level. the waste gate is set at 10 psi that is ok to break the motor in. CAN ANY ONE HELP ME JUST GET WASTE GATE HOOKED UP THAT IS COOL??????
Re: 2000 gsr turbo wastegate ??????? (acuraguy81)
if you bought the kit, it should say. look online and find the same kit you have, it should have the spring set on there.. im guessing its between 7-9 set.. hopefully. but something has to be wrong if its letting you get that much boost
u can try calling greddy and asking them what they think, also post in the FI forums if u can..
