Need help ASAP! Pressure sensing relay or for JRSC!!!
I am installing a Jacson Racing Supercharger and have everything installed, but i cannot find the pressure sensing relay. Can I finish installing the system without this relay or is it something seriously important?
Thanks for your help, i am at the middle of the install at the moment, and i am waiting on your response to finish.
Re: (MickeyA)
yeah you can install the system without the relay I had the same situation... should be able to run fine for now.. but you need to get it in soon.. gl..
Re: (Ringbearer020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ringbearer020 »</TD></TR><TR><TD CLASS="quote">yeah you can install the system without the relay I had the same situation... should be able to run fine for now.. but you need to get it in soon.. gl..</TD></TR></TABLE>
without the actual relay or switch you might be okay. But you should have the relay resistor or what ever electronics still wired up, otherwise I'm going to assume you'll run LEAN in boost.
0ptimus prime
Audio / Security / Video
10-07-2008 10:10 AM
