cutting out under boost
Old Sep 9, 2004 | 08:42 AM
LeesB's Avatar
Default cutting out under boost
I am have a slight problem I have had my turbo on for about 4 months now and just last week it started cutting out under boost and doesn't feel like my v-tec is working i have checked all the conections and grounds and pulled the codes off the ecu. Its like it has a rev- limiter at 7200 now and cuts in and out until that point, but then once in awhile it runs like a raped ape
anyone help or having the same problem?
Old Sep 10, 2004 | 01:43 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: cutting out under boost (LeesB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeesB &raquo;</TD></TR><TR><TD CLASS="quote">I am have a slight problem I have had my turbo on for about 4 months now and just last week it started cutting out under boost and doesn't feel like my v-tec is working i have checked all the conections and grounds and pulled the codes off the ecu. Its like it has a rev- limiter at 7200 now and cuts in and out until that point, but then once in awhile it runs like a raped ape
anyone help or having the same problem?</TD></TR></TABLE>
Have you checked your oil pressure? Remember VTEC relies on good oil pressure. A buddy of mine has a stock GsR integra 4dr...and he was running low on oil...it would feel like VTEC wouldn't even ingage. That would be my first bet on trying to resolve your problem.
Old Sep 17, 2004 | 01:12 PM
LeesB's Avatar
Default Re: cutting out under boost (NVturbo)
well to date i have check the oil the v-tec soliod pressure switch all connections
all grounds engine codes ect ect and still nothing even checked the timing just in case
Old Sep 20, 2004 | 11:20 AM
LeesB's Avatar
any other ideas????
Old Sep 20, 2004 | 12:56 PM
notoriousB's Avatar
have you checked your plugs & plug wires?
Old Sep 20, 2004 | 01:16 PM
beepy's Avatar
Default Re: cutting out under boost (notoriousB)
I have had this problem before. For me it was running too rich under load, and I had to reduce my gap to 0.028.
Old Sep 21, 2004 | 09:48 AM
LeesB's Avatar
Default Re: cutting out under boost (beepy)
my gap is at 28 also and i changed plugs wires and tested my coil what next
i guess maybe a break in my v-tec wire???????? I dont know where else to turn
my vafc says its hitting v-tec but i know its not
pretty messed up isnt it
Old Sep 27, 2004 | 06:47 AM
LeesB's Avatar
well on the newest update still nothing have changed everything poss v-tec solinoid (sp?) pressure switch ecu hooked a gauge to my oi pressure could it be the v-afc?????
please help
beast59
Jan 24, 2010 09:08 PM
elmalo
Engine Management and Tuning
May 2, 2009 05:27 PM
budget
Jun 22, 2006 03:14 AM
stinker504
Oct 23, 2003 08:28 PM
Ntrpriz
Jun 27, 2003 11:55 AM
