can u break in a fresh motor w/ turbo installed?
well i was searching and read up a lil on break in processes and imma prolli do the run it hard method.
i was wondering if u can break it in with turbo installed already? let me know thanks
Re: can u break in a fresh motor w/ turbo installed? (egturbo)
Im sure you can, but I think im going to pop in my hondata base map make sure my a/f is dead on and run it 1000 miles and just street tune for the low rpm band.
Re: can u break in a fresh motor w/ turbo installed? (TurboTeG4)
yeah imma prolli do that or run fmu or something but here's a link read up on it sounds like the right thing to do while breakin in the motor. what u think?
http://www.mototuneusa.com/break_in_secrets.htm
Re: can u break in a fresh motor w/ turbo installed? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">i broke my motor in with the turbo on</TD></TR></TABLE>
what method did u use?
Re: (TGARCIARACING)
There are a dozen methods. I like the "break it in like you are going to drive it" method. And in that method, you would want the turbo installed.
Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">There are a dozen methods. I like the "break it in like you are going to drive it" method. And in that method, you would want the turbo installed.</TD></TR></TABLE>
Only problem is if you break it in that way with the turbo on. yyour tuen could be so far out of wack that you can break **** at 8000RPM in boost.. I guess you could just set the boost to 0psi tho.
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Only problem is if you break it in that way with the turbo on. yyour tuen could be so far out of wack that you can break **** at 8000RPM in boost.. I guess you could just set the boost to 0psi tho.</TD></TR></TABLE>
how about if u just use fuel pump/missing link/fmu for the break in then upgrade to uberdate/hondata etc after the break in?
Re: (egturbo)
I'm currently breakin mine in with turbo in as I can't be bothered to mess about with the WG. I just try hard not to get into boost but its difficult, my eyes are glued to the boost gauge... Soon as I get above 5krpm even very light throttle spools it hard.. If you plan on running in w/boost just make sure your AFRs are very good and timing sorted with standalone.
If I was to do it again I would do it NA cos then I drive it hard futher up the rev range.
YOu will get 1093097441 opinions on break-ins, some say its better with boost as more pressure is applied to the rings compared to NA hence giving it a better seal (maybe a builder can chime in and validate this point...?) and others say boost n break-in is a no-no.
Re: (swlabhot)
i seen somewhere on honda-tech a post on where its dangerous to break in a motor untuned.......that you should just straight it up let it idle ....and get it on a dyno asap....which they made a really good point its better to break your motor in tuned.....then driving 1000miles untuned hurtin your motor.....
theres a certain procedure which i forgot i know i am sorry this is no help.....but just research and you will find it.....
i just blew my motor recently after i rebuilt it i am gonna hop on a dyno asap...
i drove my motor for 1500 miles untuned.......it had a 1.8 baseline on a hondata.....i was runnin on a 2.0 liter 9.8:1 compression.....same injectors.....
put 18kmls on a fully built block considering the hell i put it through it lasted for awhile........then i tuned it for 12psi made 332/228 then swap in a jg intake manifold and usdm itr tranny and recently blew my motor on a high speed run...i think my oil pump went out...caused me to have spun bearings....
being untune is pretty dangerous if you ask me
Re: (GunMETAL_TEgRa)
hmm yeah prolli a good idea to run it hard n/a for at least 500 miles the guy on the site i posted said the first 50 miles are the most important etc. prolli when i start her up ill take it around the block hard then hop on the freeway run it hard. then just go back and let her idle etc
If I was you I would break it in with 0 boost. When you are ready to get it tuned but it on a dyno and get it setup, just my opinon. Thats what I'm planning on doing, to much invested to screw something up Goodluck
Re: can u break in a fresh motor w/ turbo installed? (Insane)
im thinking to get my car tow to my tuner and get him to tune my freshly built engine, so basically im gonna break-in the motor on the dyno
should be ok ? ?
should be ok ? ?
Re: can u break in a fresh motor w/ turbo installed? (Day Walker)
I got my fresh engine tuned with the turbo on. I had it towed to the tuner and he broke it in on the dyno. Engine runs strong
