New form of e-cutout
Old Sep 11, 2004 | 09:53 PM
pornstarSR's Avatar
Default New form of e-cutout
I thought you all would want to know about this thing....
http://www.atpturbo.com
Old Sep 11, 2004 | 09:59 PM
1.8T_EG's Avatar
Default Re: New form of e-cutout (pornstarSR)
looks very interesting, i cant wait to see one in action. the only disadvantage i see versus standard ecutouts is that this one isnt open before boost to reduce turbo spool-up time.
Old Sep 11, 2004 | 10:23 PM
m R g S r's Avatar
Default Re: New form of e-cutout (1.8T_EG)
Yea, with my E-cutout open, I build boost faster through out the entire RPM range, so this wouldn't be that good of an idea. . . . unless it opens at like 1psi.
Old Sep 11, 2004 | 10:41 PM
RedTT's Avatar
I would think this is pretty much old news. Aerospeed makes something like this. BMWs also has these in there stock 3 series. The ones that aerospeed and BMW makes actually work better cause they close at vacuum and then open when there isn't vacuum (WOT).. The ones that ATP only opens when you boost, you'd probably need it open most when spooling up, not when you're boosting
Old Sep 11, 2004 | 10:55 PM
pornstarSR's Avatar
Default Re: New form of e-cutout (RedTT)
ok then. i know items like this have been used before...
i was just posting it as another form of an e-cutout...it was interesting to see it probably helps top end a bit... but thats a give in...
havent posted in a few months, guess im behind the time of whats cool to post and whats not
Old Sep 11, 2004 | 11:17 PM
1.8T_EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTT &raquo;</TD></TR><TR><TD CLASS="quote">BMWs also has these in there stock 3 series. The ones that aerospeed and BMW makes actually work better cause they close at vacuum and then open when there isn't vacuum (WOT).</TD></TR></TABLE>
do you have more info on the bmw ones? i googled this but i couldnt find any info. also, from what i found, the arospeed ones are not automatic, they are a mechanical and user controlled.
here's are pics of the arospeed version that i found:
looks alot like a throttle body, cable and pulley huh?
Modified by 1.8T_EG at 2:28 AM 9/12/2004
Old Sep 11, 2004 | 11:34 PM
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">ok then. i know items like this have been used before...
havent posted in a few months, guess im behind the time of whats cool to post and whats not</TD></TR></TABLE>
thanks for the post. it's new to me.
does anybody know how fast it opens? do it open right away once it sees boost?
Old Sep 11, 2004 | 11:37 PM
Ckjeepin's Avatar
Default Re: New form of e-cutout (accordfreak)
It can be a good idea. It all depends on how fast it opens..
If it takes as long as qtec cutouts then its pointless.
But i think if it opens instantly then it would be awesome.. Except for the fact that i hit 5 psi or so sometimes just driving...
Old Sep 12, 2004 | 12:49 AM
RedTT's Avatar
Oh, maybe I was mistaken with the aerospeed ones. I know the BMW ones for sure have a vacuum gated valve. On the 2002+ 3 series, they have dual exhaust. Exhaust only exits out one side until you go WOT, then the valve opens for the other side. I owned a 3 series before and disconnected that vacuum line. I guess the only way to get it would be to buy a muffler from a 3 series. It'll work better than ATPs setup but the BMW only uses 1.5" piping so you'll restrict some flow there
Pornstar, I didn't mean anything from your post. I meant to say things like this have been out, people just don' know about it
Old Sep 12, 2004 | 06:22 AM
Ri5e's Avatar
This looks interesting...hopefully the price will be right since it doesn't have any electronic parts.
Old Sep 12, 2004 | 12:29 PM
DOHCtor Boost's Avatar
I'm also looking for an e-cutout valve. But I find the Arospeed to expensive for a manual valve. besides Qtec, anyone knows of another cutout valve?
I may endup making my own.
thank you.
Old Sep 12, 2004 | 12:59 PM
Boostage's Avatar
damn!!
Old Sep 12, 2004 | 01:05 PM
ID_ten_T's Avatar
Default Re: New form of e-cutout (DOHCtor Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtor Boost &raquo;</TD></TR><TR><TD CLASS="quote">I'm also looking for an e-cutout valve. But I find the Arospeed to expensive for a manual valve. besides Qtec, anyone knows of another cutout valve?
thank you.</TD></TR></TABLE>
Please share, how would you go about making your own? Here's my idea, but I'd like to hear others too.
Use an old wastegate and a stripped throttle body. Replace the wastegate spring with a very low pressure (weak spring). Then use the push/pull motion of the wastegate to rotate the throttle body pulley and thus opening and closing the throttle plate. Once you get this working, all you have to do is mount the wastegate and throttle together and weld them to the exhaust. What do you think? Well, that's my idea anyways, let's hear others.
Old Sep 12, 2004 | 01:11 PM
I was plannong on making a CNC billet flange and stick a big TB throtle plate in there. and hook up a sort of cable to open and close it.
Old Sep 12, 2004 | 03:45 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtor Boost &raquo;</TD></TR><TR><TD CLASS="quote">besides Qtec, anyone knows of another cutout valve?
http://www.mccordcg.com/mpp/mpp.htm
Old Sep 12, 2004 | 07:41 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTT &raquo;</TD></TR><TR><TD CLASS="quote">I know the BMW ones for sure have a vacuum gated valve. On the 2002+ 3 series, they have dual exhaust. Exhaust only exits out one side until you go WOT, then the valve opens for the other side</TD></TR></TABLE>
bmw has been using the muffler cut out since the e36 body
Old Sep 12, 2004 | 08:23 PM
eddyboy's Avatar
Default Re: New form of e-cutout (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.mccordcg.com/mpp/mpp.htm</TD></TR></TABLE>
Don't forget also
http://www.dmhperformance.com/
I was planning on going with this e-cutout, but I want to see the results of this new one before I decide. I hope they are reliable, because I've seen many post about e-cutouts not holding up too well.
Old Sep 13, 2004 | 04:16 AM
RICE POLICE SIP's Avatar
Default Re: New form of e-cutout (eddyboy)
tight..... tight.....
Old Sep 13, 2004 | 11:50 AM
S2KP's Avatar
badass
Old Sep 13, 2004 | 01:14 PM
plusONE jboy's Avatar
interesting
Old Sep 13, 2004 | 02:49 PM
beepy's Avatar
I like the V-band flanges. Not going to fall off and the actuator won't break. Good stuff.
Old Sep 13, 2004 | 03:34 PM
J337_UNIT's Avatar
Default Re: New form of e-cutout (beepy)
yea i would like to know what psi that thing would open at.. it would be sick if it opened as soon as you start boosting
Old Sep 27, 2004 | 03:27 PM
pornstarSR's Avatar
Default Re: New form of e-cutout (J337_UNIT)
heres more info on the valve...
it starts opening right when you begin boosting, they dont give a psi range for the actuator but they say it opens when boost begins...
http://www.atpturbo.com/root/r...4.htm
Old Sep 27, 2004 | 03:44 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">heres more info on the valve...
http://www.atpturbo.com/root/r...4.htm</TD></TR></TABLE>
ok im def getting this..
Old Sep 27, 2004 | 03:56 PM
AlphaKennyWun's Avatar
I was going ot get a 3" exhaust but im starting to like this...
thanks for posting
