Oil line question
Old Sep 9, 2004 | 07:27 PM
jamartin0519's Avatar
Default Oil line question
Hey guys I'm having a really hard time putting my oil lines together. I bought some oil line from fast turbo however I having a really hard time putting the fittings on the metal anodized fitting on the drain lines. Do yall have any tips. Im begining to feel retarded. Please help me out. Thanks
Jason
Old Sep 9, 2004 | 08:58 PM
EJ1 wilcox's Avatar
Default Re: Oil line question (jamartin0519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamartin0519 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys I'm having a really hard time putting my oil lines together. I bought some oil line from fast turbo however I having a really hard time putting the fittings on the metal anodized fitting on the drain lines. Do yall have any tips. Im begining to feel retarded. Please help me out. Thanks
Jason</TD></TR></TABLE>
Which drain kit did you buy? The push fit or stainless steel?
I have the push fit drain line and it's hard to get on there but it should slide on with a little pursuasion...try putting a little oil around the end of the rubber and see if that helps...if you have the push fit that is
Old Sep 9, 2004 | 10:06 PM
Default Re: Oil line question (EJ1 wilcox)
I went with the stainless steel covered hose.
Old Sep 10, 2004 | 05:19 AM
MooreBoost's Avatar
Try heating the rubber hose in boiling water, that may loosen it up so that it can be pushed over the fitting. Sorry if thats not the problem, I dont quite understand.
Old Sep 10, 2004 | 06:04 AM
xenocron's Avatar
Default Re: Oil line question (tegunderpressure)
Use a clamp and lube up the ends while carefully pushing them on...clamp definitely helps.
Old Sep 10, 2004 | 06:08 AM
Muckman's Avatar
Moderator in Chief
Stan used to have a how-to section on his old website. Maybe if you email him for help he can send you those instructions.
Old Sep 10, 2004 | 11:26 AM
Default Re: Oil line question (Muckman)
Thanks guys. I'll have to try the lube. Everything works a bit better with a bit of lube .
Old Sep 10, 2004 | 11:45 AM
.dave's Avatar
i HAS questions ?
Wrap masking tape around the line before you cut it, the cut the section to length in the middle of the tape, then put some oil on it. Put the fitting in a vise and push the hose into it. Twisting the hose as you push helps as well.
Old Sep 10, 2004 | 02:57 PM
Muckman's Avatar
Moderator in Chief
Default Re: Oil line question (dave.g)
http://www.fast-turbo.com/techhelp.html
SOHC_2_DOHC
Oct 30, 2007 06:06 AM
Flexin5
Nov 7, 2006 11:41 AM
TA Performance
Feb 6, 2005 12:27 PM
TurBoXBirD16
Apr 23, 2003 08:06 PM
Snafu-Si
Jul 2, 2002 07:58 AM
