Smoking problem...need D series or anyones help
Old Sep 11, 2004 | 11:16 AM
Casey's Avatar
Default Smoking problem...need D series or anyones help
My friend has a y7 with a y8 manifold on it. It has had a vacuum leak for a while now. Last night we fixed it by plugging the small holes in the IM flange that only come on 99-00 y8 IMs.
It fixed the problem, he drove it for a mile or two, and the car started to stumble and want to cut off. He pulled over and called me. When i get there, there was smoke coming from the exhaust and around the turbo/exh manifold area. It doesnt smell like coolant or oil specifically.
I pulled the plugs, they are glossy black(ive never seen any plugs this shiny), heres a picture
im not sure if thats from running extremely rich...which in that case, what would happen if the resistor box wiring some how came loose or the resistor box took a **** on us(has 450 dsms)
could something be clogging the exhaust and causing the smoke?
pcv?
any help is greatly appreciated. btw its a greddy kit on the motor, afc(not the hack, wired normally)
Old Sep 11, 2004 | 12:34 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Smoking problem...need D series or anyones help (Casey)
doesnt even look like that plug is firing , its really really rich .
Old Sep 11, 2004 | 12:35 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Smoking problem...need D series or anyones help (Hella_JDM)
and if its a new kit , smoke from the turbo and mani is normal
Old Sep 11, 2004 | 01:00 PM
T-RO's Avatar
Its my understanding that if your resistor box went bad (never heard of it happening) that you will fry components in the ECU.
Old Sep 11, 2004 | 01:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (T-RO)
you need to adjust your afc to run those 450's , did you do that?
Old Sep 11, 2004 | 04:03 PM
Casey's Avatar
Default Re: (Hella_JDM)
yes, afc is adjusted, were using settings from the previous owner of the kit that had it tuned with the EXACT same setup. So that answers the question about being a new kit, and if its tuned to 450s
Old Sep 11, 2004 | 05:47 PM
USDM 4G VTEC's Avatar
i had that problem
btw is dat gas or oil////
i say check the wiring again
i had a fractured cable once and caused my inj to stay open
i bet $5 is a cable fractured
Old Sep 11, 2004 | 06:20 PM
Casey's Avatar
Default Re: Smoking problem...need D series or anyones help (USDM 4G VTEC)
it ran fine with the 450s installed for almost a week, it only happened after we took the IM off and filled the cold air idle holes(i think) to seal the leak
Old Sep 11, 2004 | 06:31 PM
yea
my car ran fine for 1 mth
it only takes the moving of the harness around to fracture a cable
Old Sep 11, 2004 | 06:52 PM
Casey's Avatar
Default Re: (USDM 4G VTEC)
which wire are you referring to? one of the ones regarding the resistor box?
Team_Insane
May 12, 2011 08:25 PM
Infinityzer050
Jun 16, 2007 01:34 PM
utahbmx
May 4, 2005 02:21 PM
WildPig
Jan 23, 2005 09:17 PM
hondaciv3
10
Sep 14, 2004 06:38 AM
