is it time for rings???
Old Sep 9, 2004 | 12:19 PM
jdmtim's Avatar
Default is it time for rings???
did a compression test today with these results:
cyl 1= 155
cyl 2= 165
cyl 3= 160
cyl 4= 165
Old Sep 9, 2004 | 12:43 PM
notoriousB's Avatar
Default Re: is it time for rings??? (jdmtim)
what motor? the #'s are at least very close to each other, that's not a bad sign
my motor: 225, 225, 120, 230 doing a swap tomorrow
Old Sep 9, 2004 | 12:44 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmtim &raquo;</TD></TR><TR><TD CLASS="quote">did a compression test today with these results:
cyl 1= 155
cyl 2= 165
cyl 3= 160
cyl 4= 165
did you hold down the accelerator while turning the engine? Did you let it crank through 5+ revolutions?
Old Sep 9, 2004 | 01:07 PM
jdmtim's Avatar
it's a b18a, after pulling the plug crank car holding down clutch and accerator
Old Sep 9, 2004 | 01:08 PM
2SlowDC's Avatar
thats wierd. usually rings dont go out at the same time. i think u may have bent valves
Old Sep 9, 2004 | 01:12 PM
White Smoke's Avatar
i my honda
Global Mod
What compression ratio are you running? Those #'s dont look that bad.
Old Sep 9, 2004 | 01:15 PM
jdmtim's Avatar
the c/r is 9.2:1 bored .20 over
Old Sep 9, 2004 | 01:22 PM
toolowsol's Avatar
look like pretty good numbers to be, don't worry about it
Old Sep 9, 2004 | 01:29 PM
jdmtim's Avatar
trying not to worry but, I'm burning oil something serious!! What could be what else should I check.
Old Sep 9, 2004 | 01:38 PM
jdmtim's Avatar
think maybe turbo bearings go bad????
Old Sep 9, 2004 | 01:39 PM
toolowsol's Avatar
check for oil in your charge pipe, and what are you using for crank case ventalation?
Old Sep 10, 2004 | 05:55 AM
jdmtim's Avatar
I'll check the charge today
Old Sep 10, 2004 | 07:12 AM
Muckman's Avatar
Moderator in Chief
improper cam timing could cause poor compression across all cylinders.
check your tbelt.
Old Sep 10, 2004 | 08:13 AM
jdmtim's Avatar
cam timing is at 0 intake 0 exhaust ignition is fully retarded (sounds funny)!
Old Sep 10, 2004 | 09:09 AM
jdmtim's Avatar
cheeked all charge pipes and these no oil inside of them??? WTF??
Old Sep 10, 2004 | 09:16 AM
Boosted2K's Avatar
Numbers seem good, some testers tend to read lower. Who is this?? I noticed you live in the same town as me. I know you are a tral user so you can't use PM. Drop me a email if you like (spchowell@hotmail.com) maybe we could help each other out, I'm always looking for **** to buy.
Old Sep 10, 2004 | 10:41 AM
mike1114's Avatar
Default Re: is it time for rings??? (Boosted2K)
valveseals. Replace them.
I bet you your car smokes some during startup after sitting all night then after a few it pretty much goes away?
sol_tuner
Feb 23, 2005 03:15 PM
RAS Motorsports
Dec 10, 2003 05:16 AM
RedRacerCivic
11
May 22, 2003 10:29 AM
gsr~hatch
Apr 17, 2003 03:19 PM
google
Apr 12, 2003 08:40 PM
