upgrade to sc61?
Old Sep 10, 2004 | 04:42 PM
markaria's Avatar
Default upgrade to sc61?
I currently have a 83mm benson b18c5 block (9:1 cp's & pauters) w/ stock '97 itr head and ctr cams, as well plenty of fuel (750cc rc's/hondata/walbro255/aem fpr/rail) and a t3/t4 turbonetics .48 exhaust and 60 on the compressor with a sfp manifold and 2 1/2" intake plumbing.
Also my exhaust is a full 3" downpipe to a 3" thermal.
On a mustang dyno the car put out 292 whp @15psi and 331 @ 19psi when i still had my full 2 1/2" downpipe/exhaust.
When I upgraded to the full 3" downpipe + 3" thermal, I got 310whp @15psi and a misfire @ any higher boost kept me from upping the boost. At this rate I figured it would probably take me 25+ psi to hit 400+ hp. I have since changed plugs and wires and regapped (.26) on a 2 step colder plug and the misfire is no longer an issue.
My questions are: 1)will an sc 61 help me achieve 400+whp (on a mustang dyno) without having to boost at crazy psi levels (25psi+)?
2) at the 400hp level are my ctr cams gonna need adjustment (I have skunk cam gears but they are not adjusted)?
3) is an itr intake mani and throttle body limiting my #'s?
4) will my piping/downpipe need much modification going to a sc61 from my t3/t4?
5) will my wife divorce me soon if I keep spending...oh who cares
Old Sep 10, 2004 | 10:56 PM
markaria's Avatar
Default Re: upgrade to sc61? (markaria)
any input would be greatly appreciated...
Old Sep 10, 2004 | 11:13 PM
95GSRTT
Guest
Posts: n/a
the sc61 will easily produce more power at lower psi.
Old Sep 10, 2004 | 11:45 PM
Rod.'s Avatar
Default Re: upgrade to sc61? (95GSRTT)
we have the same bore, same benson block, i have 3" downpipe and exhaust. At 8psi on a sc61 made 300...at 10 made 331...i have a dyno chart of 368 forgot what boost that was on..it was before 14 all I know
Old Sep 11, 2004 | 12:53 AM
ebp 99 si's Avatar
Default Re: upgrade to sc61? (redturbocivic)
sc61 is a good turbo
but you could always go with this
https://honda-tech.com/zerothread?id=971894
Old Sep 11, 2004 | 01:09 AM
D-tuned's Avatar
Default Re: upgrade to sc61? (ebp 99 si)
I have a precision sc-61 and I put down 397WHP at 10psi @ Abacus.
Old Sep 11, 2004 | 04:10 PM
markaria's Avatar
thanks to all that have replied...any input on my other questions?
Old Sep 11, 2004 | 04:23 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si &raquo;</TD></TR><TR><TD CLASS="quote">sc61 is a good turbo
https://honda-tech.com/zerothread?id=971894</TD></TR></TABLE>
promoting yourself
Old Sep 11, 2004 | 05:39 PM
ebp 99 si's Avatar
Default Re: upgrade to sc61? (Sweet Lou)
just tryin to help
Old Sep 11, 2004 | 11:47 PM
markaria's Avatar
ttt
Old Sep 12, 2004 | 04:00 PM
markaria's Avatar
any other input?
Old Sep 13, 2004 | 07:46 PM
markaria's Avatar
Old Sep 13, 2004 | 08:01 PM
b18prl's Avatar
B 16 je/crower ctr cams custom mani full t04 sc61 880 inj s100 b@20 lbs made 406whp had to rev to 9600.
Old Sep 14, 2004 | 06:15 PM
markaria's Avatar
One last bump
Old Sep 14, 2004 | 06:55 PM
AlphaKennyWun's Avatar
I used to have a .48 t3/t4 turbo and I upgraded to an SC 61 a year ago.
I have a B18c 81 mm block.
I want a larger turbo now.
eshlil
Mar 17, 2007 11:44 AM
XEek4
Jun 19, 2006 07:09 AM
TypeGSR196
Apr 25, 2006 01:59 PM
d_mina
Jun 15, 2004 01:53 PM
mike1114
Dec 31, 2003 02:38 PM
