Not Starting after Turbo Installed
I have a 00 B18B1...ive just installed the turbo on it today..after i finish all the installation the engine will not crank over...any ideas of what might of cause it to not carnk over....or some common turbo mistake that can happen...
Re: Not Starting after Turbo Installed (beepy)
maybe battery dead since you were prolly playing music durings installation just an assumption....just playing.......it shouldn't be anyhting related to the turbo.....
check for blown fuses and what not loose starter connectors
Re: Not Starting after Turbo Installed (Endoe)
Did you check the volatage on the battery? Did you make sure the connectors are on tight and that you did not undo the ground for the battery. Is the car turning over at all and just not starting?
If it is not cranking over then start with the basics. Check that or reply if all that is good.
Did you pull a plug and ground it out to see if you are getting spark?
Re: Not Starting after Turbo Installed (underpressure02)
check all plugs and relays...getting sparks...hear fuel pump go on...battery is good, tried it on a van and it started right up...it has grounds.... im thinking it might be the fuel pump or fuel filter...im gonna try putting the stock fuel line back on...well see from there..
Re: Not Starting after Turbo Installed (Mase)
Installed the fuel pump backward.....engine cranks over... but now fuel pump is making weird noises..like it is struggling or something....
