changing cam timing alters A/F ratio?
Old 09-07-2004, 06:17 PM
Turbo E's Avatar
Default changing cam timing alters A/F ratio?
as title says:
yes or no?
do i have to re dyno if a few changes are made?
Old 09-08-2004, 08:13 PM
PrettyLude's Avatar
yes it will affect the a/f ratio
Old 09-08-2004, 08:37 PM
95GSRTT
Guest
Posts: n/a
Default Re: changing cam timing alters A/F ratio? (Turbo E 604)
well think about it, you are changing the duration and lift of when and how much air goes in and out. its gonna screw with the air...
Old 09-08-2004, 08:42 PM
Ekasey's Avatar
Default Re: changing cam timing alters A/F ratio? (95GSRTT)
like title says: yes
Old 09-08-2004, 09:08 PM
Mase's Avatar
Default Re: (PrettyLude)
it will slightly, but unless you change the cam timing drastically, its not gonna throw it off that much...
Old 09-09-2004, 12:18 PM
Turbo E's Avatar
only 1-2 deg.
lsvtec101
04-26-2004 11:28 AM
Red_Si
04-20-2004 07:21 PM
fe519
10-31-2002 02:03 PM
Civic_95_Si
10-24-2002 01:09 PM
Quick Reply: changing cam timing alters A/F ratio?
