need opinions on block problem
Old Sep 8, 2004 | 09:57 PM
SSBPGSR's Avatar
Default need opinions on block problem
ok heres the problem: TURBO HITS BLOCK, not enough to prevent it from being installed, but enough to make a leak that pisses me off
everything is insallted, tuned for 6.3psi and pulls hard. but i have an exhaust leak from the manifold/head. yes i used a new gasket and all the bolts were tightend and retightend. so i guess what im lookin at is new manifold or notch the block?
i have a revhard manifold with a turbonetics t3t4, the compressor housing hits the webbing on the block, has anyone notched their block? if so what did you use, and what was the outcome? i am a little low on funds right now, but if it means weakening the block ill stick out some black sut on the head untill a new manifold is within my reach. and this is all on a 98 GSR ..thanks for the help guys
also didnt know where this post belongs. sorry, feel free to move. (like i have any say anyways )
Old Sep 8, 2004 | 10:08 PM
Ekasey's Avatar
Default Re: need opinions on block problem (SSBPGSR)
Notch the block mine is!
It won't weaken anything i used a cut off wheel
Old Sep 9, 2004 | 12:26 AM
AspectIndustries's Avatar
Default Re: need opinions on block problem (eLusive ek4)
A little grinding wont hurt.
Old Sep 9, 2004 | 06:44 AM
Muckman's Avatar
Moderator in Chief
Just a little off the top will do.
Old Sep 9, 2004 | 07:08 AM
SSBPGSR's Avatar
Default Re: need opinions on block problem (Muckman)
thanks guys, ill post up some pics after everything is fixed and the engine bay is cleaned up a little bit.
Old Sep 9, 2004 | 07:25 AM
RA166E's Avatar
Grind to fit. It work for me.
eg:R
Apr 19, 2014 08:56 AM
10SecDSM
Sep 15, 2006 08:11 AM
AirWaveGT
Jul 20, 2004 11:09 PM
Muckman
Jan 16, 2004 09:31 AM
TedR719
Sep 23, 2003 03:11 PM
