Defi gauge recall
Old Mar 18, 2006 | 03:29 AM
Dee's Avatar
Dee
Default Defi gauge recall
warranty card info
043011C (ターボ計) boost
045011C (燃圧計) Fuel pressure
046011C (油温計) oil temp
047011C (水温計) water temp
048011C (排気温度計) EGT
050011C(コントロールユニットの番号) control unit
If you do not have the warranty card check the back of your gauge. If you have a BF white series gauge from 2001 that does NOT have a serial number on the back you have one of the recall gauges. These gauges have been known to overheat and start fires.
Contact DEFI-USA if you have one of the recall gauges.
Defi Japan recall page in JAPANESE.
Recall gauge w/o SN
Gauge that is OK
Warranty card - check the number in the 2nd block
Old Mar 22, 2006 | 03:09 PM
Dee's Avatar
Dee
Default Re: Defi gauge recall (Dee)
Just want to make sure you guys have seen this! If you have the older gauge you need to get it replaced!!
FIRE HAZARD!!!
JDM_EK4_Coupe
Jun 19, 2007 03:49 PM
B00ST2nR
Jun 8, 2004 07:07 AM
RCautoworks
30
May 9, 2003 06:42 PM
Hybrid
Feb 14, 2002 10:30 AM
