Turbo ITR Problems
Old Mar 14, 2006 | 11:03 AM
VtecKiDD's Avatar
Default Turbo ITR Problems
Turbo ITR
10:1 JE pistons
Eagle Rods
Drag 3 bolt on kit
Heres the problem, motor HITS vtec, can hear it audibly, 70psi of oil pressure AFTER the vtec solenoid so there enough pressure. Solenoid is working properly, not clogged or anything. Car holds boost , no boost leaks (9psi)
Car hits vtec and falls on its face. This is a brand new Honda head, that the customer had smoeone else assemble it. Im thinking the rocker arms are only engaging on certain cylinders. only thing i can think of.
Old Mar 14, 2006 | 11:07 AM
93turbo16's Avatar
Check cam timing?
Old Mar 14, 2006 | 11:13 AM
VtecKiDD's Avatar
Default Re: (93turbo16)
Cam timing is SPOT ON
Old Mar 14, 2006 | 11:17 AM
93turbo16's Avatar
Default Re: (VtecKiDD)
I had a similar problem with a car, and the intake cam was retarded a good bit. That is all I can say from a personal experience. Hopefully it is something dumb like that and not internal.
Old Mar 14, 2006 | 11:30 AM
T3T495GSR's Avatar
You definately have a problem if that is your dyno graph
Old Mar 14, 2006 | 12:00 PM
Meat_Wagon's Avatar
Default Re: (T3T495GSR)
I have seen similar graphs when the timing belt is a tooth off.
Old Mar 14, 2006 | 12:02 PM
B18 CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR &raquo;</TD></TR><TR><TD CLASS="quote">You definately have a problem if that is your dyno graph</TD></TR></TABLE>
Isn't that why he posted here?
Old Mar 14, 2006 | 12:06 PM
Mag00n's Avatar
Old Mar 14, 2006 | 01:01 PM
s2kdre's Avatar
Default Re: (Macan00n)
whats the gap on those plugs?
Old Mar 14, 2006 | 01:30 PM
nonvtecD's Avatar
Default Re: Turbo ITR Problems (VtecKiDD)
I have had timing off a tooth and never had a motor react like this. I think it's internal.
Old Mar 14, 2006 | 01:35 PM
Turbo-charged's Avatar
Default Re: Turbo ITR Problems (nonvtecD)
whats the compression test results?
i would assume the car drives and idles fine....all is well...then once you hit vtec it feels like a turd? does it break up and buck and sputter and ****....or just not make any power...sometimes the graphs dont completley resemble how the car "feels" on the dyno
Old Mar 14, 2006 | 01:45 PM
mrbsponge's Avatar
mine dod the same thing, as far as power, intake cam was reatrded 10 degrees. cam gear bolts slipped.
i know you said you checked the cam timing. but i would definetley re time the car with a good light
Old Mar 14, 2006 | 01:46 PM
93turbo16's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">mine dod the same thing, as far as power, intake cam was reatrded 10 degrees. cam gear bolts slipped.
i know you said you checked the cam timing. but i would definetley re time the car with a good light</TD></TR></TABLE>
That was exactly what I thought the first time I looked at the graph.. I had a car that was retarded like 5-6 degrees on the intake and it did the same thing..
VtecKiDD's Avatar
Default Re: Turbo ITR Problems (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">whats the compression test results?
i would assume the car drives and idles fine....all is well...then once you hit vtec it feels like a turd? does it break up and buck and sputter and ****....or just not make any power...sometimes the graphs dont completley resemble how the car "feels" on the dyno</TD></TR></TABLE>
Compression was 200-200-200-200
Plugs are gapped accordingly, no blow by, no smoke, no burning oil. car idles fine, timing belt and cam timing is dead on the money, reset it twice just to be sure.
car drives fine until vtec then falls on its face. the customer , as i said, bought this head brand new dissasmbled from honda. im thinking some of the rocker pins are missing in the head, im gonna pull the cams out tomrrow
Old Mar 14, 2006 | 01:47 PM
D@nnY's Avatar
take off the valve cover and look at the cams. Make sure the vtec lobes arent ground down or screwed up...
look at the middle rocker arms and make sure each one has the pin installed inside of it.
you may have to take off the cam caps and see if the oil restrictors are there
VtecKiDD's Avatar
Oh yeah, STOCK CAM GEARS, non adjustable
Old Mar 14, 2006 | 01:50 PM
D@nnY's Avatar
also make sure your wideband isnt fubar
Old Mar 14, 2006 | 01:56 PM
VtecKiDD's Avatar
we dynoed a 622whp car the day after, wideband is ok
Old Mar 14, 2006 | 02:09 PM
99B16Si's Avatar
have u tried to shut off vtec and make a full pass without it?
bad coil maybe?
Old Mar 14, 2006 | 02:12 PM
TurboR1391's Avatar
Default Re: (99B16Si)
Had the same problem with an engine in my friends car. Timing belt was a tooth off.
Old Mar 16, 2006 | 05:45 PM
VtecKiDD's Avatar
Default Re: (TurboR1391)
still cant find the problem. All the rockers have their pins, timing belt is still dead on. motor runs and drives fine, just falls on its face in vtec
Old Mar 16, 2006 | 06:02 PM
D@nnY's Avatar
can you put an oil pressure gauge on the motor.....ive seen them go into vtec and as they rev fall back out due to oil pressure....it mechanically will not be in vtec and it will be runnign the vtec map in the ecu and run like ****
Old Mar 16, 2006 | 06:05 PM
93turbo16's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">can you put an oil pressure gauge on the motor.....ive seen them go into vtec and as they rev fall back out due to oil pressure....it mechanically will not be in vtec and it will be runnign the vtec map in the ecu and run like ****</TD></TR></TABLE>
Just like my damn K20.
Old Mar 16, 2006 | 06:06 PM
MidShipCivic's Avatar
Ok, your suppose to route the air that the compressor blows out to the throttle body.
Old Mar 16, 2006 | 06:16 PM
VtecKiDD's Avatar
Default Re: (MidShipCivic)
ok, here what i did:
Plugged all the holes in the head, ran 100psi of air pressure through the allen key hole in the front of the solenoid.
The rockers lock together, but very loosely, the pins basically slide together, but they dont LOCK
interesting.....
