engine miss...help me read plugs!
Old Mar 16, 2006 | 03:29 PM
gitwidit's Avatar
Default engine miss...help me read plugs!
Running a little rough around town. Engine kept stalling when I'd come to a complete stop. Pulled the plugs and this is what I found.
What do you think...I'm new to the "tuning" thing.....maybe pull some timing or add fuel?
Old Mar 16, 2006 | 03:32 PM
ccivic's Avatar
Default Re: engine miss...help me read plugs! (GITWIDIT)
They look a little lean.
How'd that happen
Old Mar 16, 2006 | 03:36 PM
wantboost's Avatar
Who is Mr Robot?
im ASSuming this is a joke?
Old Mar 16, 2006 | 03:37 PM
gitwidit's Avatar
Default Re: engine miss...help me read plugs! (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">They look a little lean.
How'd that happen </TD></TR></TABLE>
I don't know...maybe I got some bad gas
Old Mar 16, 2006 | 03:38 PM
mrbigg9032's Avatar
This will be funny!!!!
gitwidit's Avatar
Default Re: engine miss...help me read plugs! (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">im ASSuming this is a joke?</TD></TR></TABLE>
nothing to joke about man
I was running on a basemap...dude said it was cool.
adictionbass's Avatar
actually, i think ur running a little too rich
Old Mar 16, 2006 | 03:39 PM
Turbo_TONY's Avatar
holy crap ........
Turbo_TONY's Avatar
Default Re: engine miss...help me read plugs! (Turbo_TONY)
it looks like they are not all the same type...are they?
Old Mar 16, 2006 | 03:40 PM
gitwidit's Avatar
I'm running NGK's y0
Old Mar 16, 2006 | 05:44 PM
B6tPoweredMx3's Avatar
meh, put them back in and up the boost
Old Mar 16, 2006 | 06:11 PM
Sketch_hs's Avatar
haha
Old Mar 16, 2006 | 08:07 PM
Tactic$'s Avatar
Default Re: engine miss...help me read plugs! (B6tPoweredMx3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tPoweredMx3 &raquo;</TD></TR><TR><TD CLASS="quote">meh, put them back in and up the boost </TD></TR></TABLE>
Old Mar 16, 2006 | 08:14 PM
T3T495GSR's Avatar
Default Re: engine miss...help me read plugs! (Tactic$)
They look like RUST
Old Mar 16, 2006 | 08:15 PM
96 GSR-T's Avatar
you might of broke pieces of your piston off and hit the spark plugs causing that one to be broken, exactly what my plug looked like when I did that.
Old Mar 16, 2006 | 09:08 PM
dunkd's Avatar
looks like a combination of fucked up plugs... maybe if they were all the same plug model you'd fool me
Old Mar 17, 2006 | 01:27 AM
blackeg's Avatar
Default Re: (dunkd)
repetitive watching of fast and the furious on your in car ice has overloaded your electrical system, causing you to mess up the injector pulses, run lean and detonate.
Old Mar 17, 2006 | 04:47 AM
gitwidit's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">repetitive watching of fast and the furious on your in car ice has overloaded your electrical system, causing you to mess up the injector pulses, run lean and detonate. </TD></TR></TABLE>
That movie rocks my fav
I called Autozone to get new plugs...they said they're special order only
Should I spray'em with some brake cleaner and put'em back in?
Old Mar 17, 2006 | 05:41 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (GITWIDIT)
i say put some rust remover on them and turn the boost up to 25psi. it should solve the issue
Old Mar 17, 2006 | 05:50 AM
igo4bmx's Avatar
solder on a paperclip on the spark plug for more spark
Old Mar 17, 2006 | 06:31 AM
gitwidit's Avatar
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">i say put some rust remover on them </TD></TR></TABLE>
I think I'm gonna put some rustoleum on this time and jb weld them in to keep the water out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">turn the boost up to 25psi.</TD></TR></TABLE>
You mean turn the boost down to 25psi?
Old Mar 17, 2006 | 06:47 AM
TurboGoKart's Avatar
Actually it looks like a combination of running lean, and braking too hard. I've noticed a lot of times that when I brake really hard, my car tends to miss and stutter some. It's pretty noticable. I think it's the same with yours apparently. I havent found a fix yet though. I tried putting stiffer springs in the front, but it didnt really help. Best of luck to you.
Old Mar 17, 2006 | 06:52 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">I think I'm gonna put some rustoleum on this time and jb weld them in to keep the water out
You mean turn the boost down to 25psi?</TD></TR></TABLE>
i tihnk that would work too! awesome man
EngineNoO9
Honda Motorcycles
13
Nov 8, 2008 07:05 AM
1.8L_allmotormilitia
Sep 13, 2007 11:43 AM
matman4444
Jul 6, 2005 10:15 PM
zseeanz
Dec 2, 2003 07:25 AM
1JDMEF9
Nov 5, 2003 09:32 AM
