What can i run with..
Old Mar 15, 2006 | 09:42 AM
smokedyou19's Avatar
Default What can i run with..
Ok over the summer I am planning on gettign a turbo kit for my h22 lude prob a drag kit. Now i know i can run 6/7 psi on stock block and stuff. Now the question is what can i run if i built up my block from bottom to head like everything done..
Thanks in advance
Old Mar 15, 2006 | 10:07 AM
B18 CYA's Avatar
Everything done...hmm...hell run 45psi
Old Mar 15, 2006 | 10:23 AM
T25So's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">Everything done...hmm...hell run 45psi </TD></TR></TABLE>
And suck down street signs n ****!
Old Mar 15, 2006 | 03:57 PM
Default Re: What can i run with.. (smokedyou19)
my block wont crack or anything? I thought the h22a block is not good but i guess if everything is in it it should be fine
Old Mar 15, 2006 | 04:07 PM
The Weather Man's Avatar
You're getting it sleeved right?
If not, you'll have to get the Mahle Gold series pistons. They work damn well though.
I dont' think the block should crack until you get in the 400hp range. To be safe - don't go over 300whp on a stock block.
Old Mar 16, 2006 | 05:34 AM
tekturbo's Avatar
Thats crap your blok will not crak even if you dont get all those pistons and crap all you need is a high boost head gasket,arp headstudkit,good fuel management like hondata,neptune,and so forth injectors to match what ever boost the turbo is puttin out and a kick a** tunerand ur good trust me I know . People get the whole boost thing confused its not about the psi its about the tuning I have friends with stock bottom ends on Ls,gsr h222 you name it runnin 10 to 15psi daily driven but fine tuned not no b.s tuner . remember its all in the tuning honda engines on boost and stock internals tuned will last just as long as wrx gsx and all those others all wheel drive pieces of sh**
Old Mar 16, 2006 | 05:38 AM
Ok. Thats all bullshit.
Do NOT listen to ^^ that guy. He obviously knows nothing. The weakest part of an h22 are the ringlands and they WILL crack.
We do not have the same thing as B series engines. Their pistons can handle a lot more. Don't take shortcuts with the h22. Coming from someone with an H22.
And PSI doesn't matter - its the amount of HP you're making. And he won't last long at 300whp at all. He'll break down very quickly. Yes tuning is key; however, if something is weak - tuning can't make it "STRONGER" per se.
Old Mar 16, 2006 | 11:35 AM
Topdawgg's Avatar
wow.. there is alot of WRONG info in here...
for one, it depends if its an open deck block or not...
I for one used to think that h22s didnt like boost... but recently there have been a bunch of 300+ whp h22 turbo setups around here... runnin 8-12 psi
Old Mar 16, 2006 | 11:42 AM
Well on the safe side what should i do for my block besides the pistons and stuff. to get into double digits in the psi. i know you said it doenst matter about the psi but if your run alot of psi that would automatically give you more hp..What would you recommend getting done to run like 15 psi on a stock block
thanks
Old Mar 16, 2006 | 02:01 PM
Topdawgg's Avatar
pistons rods and head studs should allow you to run 15 psi on it... as long as its a good tune, you should be fine
Old Mar 16, 2006 | 06:30 PM
Default Re: (Topdawgg)
are the head studs the same for the h22a4 and the h22a1..bc i was looking and they only have them for the h22a4
Old Mar 17, 2006 | 02:29 PM
tekturbo's Avatar
who ever that was that said i dont kno what I am talking about sounds like he never ran boost before we just recently boost an h22 stock internals and fine tuned on 10 psi no probs , also for the record if you kno n e thing about tuning he also gets 30 miles to the gallon read ur books and get ur facts straight before you try to get at me because you prob think its all about pistons and crap when its not you can still fail with the best pistons and sh**
mikeaitken
Apr 15, 2007 06:20 AM
blackeg
Jan 25, 2007 06:17 PM
My292Ludes
Sep 6, 2006 12:42 PM
ChrisUlrich
Honda Civic (2001 - 2005)
Jun 24, 2006 10:02 PM
Howitt
Sep 24, 2002 06:30 PM
